Previous Thread This topic has been viewed 8212 times and has 2 replies Next Thread
lalberts
setting new walls..
I would wish a constantly open window where you change your wall thickness as you set your wall..
set, then modify attributes, click ok, set a new (not appropriate) wall, reopen the attributes window, redefine thickness, click ok,.. this is not really fast..
Having this attribute window open all-time and of course changing the walls as you type the values, this would speed up this first step of reading in plans..
newbie, still in phase1, reading in plans.
thanks
Lukas
[Aug 21, 2016, 11:39:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
danger89
Re: setting new walls..
uh yea agreed! After creeating 4 houses and 140 walls later it's a hell.
We need a feature to update several items as once, with similar objects likes multi selection of walls in this case.
[Nov 1, 2016, 10:52:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want to change the thickness of more than a wall at the same time, select them and choose the Plan > Modify walls menu item. You may even choose this menu item if the selection contains something else!
[Nov 1, 2016, 11:51:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
