Previous Thread This topic has been viewed 5005 times and has 2 replies Next Thread
mazoola
Export bugs
Emmanuel -
I've opened two tickets on the export issues I reported -- namely, incorrect illumination model exported and texture images resized on export. I've discovered the second problem also affects objects imported using the Furniture Library editor and saved in a .SH3F file, so the resizing may be a part of the import process. (At least, I've discovered it affects objects saved in the library in OBJ/MTL format. In examining furniture libraries exported from SH3D using the 'export imported furniture' [or whatever it's called; I'm currently writing from a machine w/out SH3D installed] command on the 'Furniture' menu, I see objects may be saved in either Lightwave or Collada format. What determines which format is chosen?)
Thanks,
maz
[Jul 1, 2016, 12:43:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Export bugs
Thanks for opening the tickets.
I saw your issues but didn't test them yet.
[Jul 1, 2016, 2:02:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
Re: Export bugs
I know: I always seem to forget to open a ticket... unless I'm on the receiving end, when I'm a real SOB about everything being properly documented. I figured I'd do it right this time. smile
[Jul 1, 2016, 4:11:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
