Posts: 44   Pages: 5   [ Previous Page | 1 2 3 4 5 ]
Previous Thread This topic has been viewed 284456 times and has 43 replies Next Thread
D5KjC6RC
Re: Sweet Home 3D 5.3
After several issues with SH3D 5.2 on Linux (Graphical issues and crashes with WebStart, long startup time with installer), I'm glad to see after some testing that the 5.3 release supposes to be much stabler on Linux.
I can confirm the notable performance decrease - although more related to the plan instead to 3D. In fact, it's not really usable anymore from an UX perspective. So I'll unfortunately have to continue with 5.2 for now
However, awesome product!
[Nov 15, 2016, 11:09:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 5.3 Beta 14 comes with the following features/fixes:
- Textures coordinates on floor borders are computed differently to ensure textures are always showed correctly: textures are now mapped from bottom to top and starting at each room point.
- Selected items are kept visible in the plan when Zoom in or Zoom out tools are used.
- Scale and origin of an imported background image are initialized from the values of the image available at previous or next level when it exists.
- When a background image is used, walls are painted with a half transparent pattern while drawing them or while placing doors and windows.
Final version 5.3 should come soon smile
Okh, your WiFi connection malfunction is strange. Sweet Home 3D doesn't use Internet except at start to check if there's a new version. Could you disable updates check in preferences to see if it behaves better? The extra spacing you report in the catalog must come from the long information you set on one item.
D5KjC6RC, thanks for your feedback, even if your report is worrying. If you feel that version 5.3 beta isn't usable, I wonder if I should use Java3D 1.6.0 or not. But as you think that slowness doesn't come from the 3D part, I'll see if it comes from the Java version itself.
[Edit 1 times, last edit by Puybaret at Nov 16, 2016, 11:11:13 PM]
[Nov 15, 2016, 7:45:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Under Mint 18 the program opens, displays an error message concerning some error in de 3D rendering system, and tells me to update my DirectX/OpelGL drivers, then closes.
Using the Jar version displays the same message.
Version 5.2 runs without problems.
[Nov 15, 2016, 10:52:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Looking forward to it and the xml approach.
Yes it is pretty strange... Tried beta 14, with and without Update Check. Everything seems ok. At one point, I did indeed loose my WiFi connection again, but I do not think it is SH3D as such that kills it. I think it may have to do with many programs simultaneously accessing the 64 GB SD card, generating read/write errors and taking down Windows Explorer. But then it is NOT a SH3D issue, it is a problem with how the system mounts the SD card. Will let you know if it happens in some sort of identifiable way related to SH3D.
That is what I thought. But I suppose it is new to 5.3 as my libraries did not change since 5.2.a. Probably few people will notice as not that many use information fields in the libraries extensively. But I would prefer the more compressed view with title and first line of the information fields so I can see more models at the same time. I also tried the Category folders view, and there too there are some oddities with how info is presented. Sent you screenshots.
[Nov 16, 2016, 10:03:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Version 5.3 was released tonight. Thanks to you all for your feedback and your support smile
Hans, I finally added a second executable command file named SweetHome3D-Java3D-1_5_2 to Linux installers, to let you and people who feel that performances with Java 3D 1.6.0 are not good, run Sweet Home 3D with Java 3D 1.5.2. From the feedback of more Linux users, we'll see if finally I can get rid of Java 3D 1.5.2 in installers one day or the other.
Remember that the Java option -Dcom.eteks.sweethome3d.j3d.version=1.5.2 lets you also run Sweet Home 3D executable Jar with Java 3D 1.5.2 under Windows and Linux, and that the Java 3D version in use is now indicated in the About dialog box.
[Nov 16, 2016, 11:22:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
D5KjC6RC
I can confirm that there is no performance impact anymore after switching from bundled jre8 to (5.2 bunndled) jre1.6.0_45.
[Nov 17, 2016, 12:02:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
D5KjC6RC
Just noticed that performance degrades as well, when opening a home with sh3d-5.3(jre1.6.0_45) that has been previously saved by sh3d-5.3. That's to day, I experience only "good" performance by using the old JRE with 5.2 version homes.
Now I'm wondering whether the performance issue could be related to:
http://stackoverflow.com/questions/28504943/j...slower-after-jvm-8-update
[Nov 18, 2016, 7:17:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
