Re: Sweet Home 3D 5.3
@Puybaret
Introducing this new Home.xml entry in .sh3d files will help programmers who want to reuse homes designed with Sweet Home 3D in other applications programmed in languages different from Java...
With what 3D rendering software the file Home.xml is compatible? Kerkythea accepts the .xml format but there is an error during the import.
EnkoNyito
After a discussion about the evolution of the .sh3d format with some French experts, it seemed better that the Home.xml uses some XML elements and attributes close to the classes of the model layer, rather than an existing XML format like Collada or BIM XML. Just open a Home.xml and you'll recognize the data handled by Sweet Home 3D classes. I don't dream of creating a new standard, but at least this should help to exchange data with other programs if needed.
Hi Emmanuel Just realised it is not only textures that are giving an issue. I have 2 items, a sliding door that i created in sh3d and part of a fire escape also created in sh3d, each time i open the prog they have reverted to thier original color. I can email you the sh3d file as it is quite small.
Thanks Mike for your file and the description of your problems. I was able to fix the issues in the version 5.3 Beta 8.
This new Beta version allows to change again the angle of a texture and fixes an error during file opening that ignored the color of items which belong to a group. Unfortunately, this second bug provoked a loss of the color information of these items when the opened file was saved with the Beta 7. I hope you tried that Beta version on copies of your sh3d files as recommended, otherwise you'll have to change the color of the grouped items again.
Under Linux, the Beta 8 version should also fix a bug that grayed the 3D view when Sweet Home3D window was activated/deactivated. I didn't find yet why navigating in the 3D view runs slower than with version 5.2 under that system. More feedback and ideas on this point would be very appreciated.
Finally, this version 5.3 might contain only the .sh3d file format change and bug fixes. Some Windows and Linux users waited for corrections on critical bugs for quite a long time now, and I feel it would be better not to wait more weeks. Hope you'll agree.
[Edit 5 times,
last edit by Puybaret at Nov 16, 2016, 11:09:36 PM]
Hi Manu,
It works with the "fire of God" at home (french expression) and my signature is updated.
I'm a returning user and I thought I'd try the latest, so I downloaded the 5.3 beta8 jar to run on osx 10.10.5, java 1.8.0_45.
Everything seemed to be fine, I started editing a new plan, saved it and quit, but when I went to open it again nothing seemed to happen. I ended up running the jar from the command line with > java -Xmx640m -jar SweetHome3D-5.3.beta8.jar So that I could see if there was any console output to indicate a problem. And sure enough when I tried opening my file I got the following stack trace:
java.lang.NullPointerException at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1838) at sun.misc.FloatingDecimal.parseFloat(FloatingDecimal.java:122) at java.lang.Float.parseFloat(Float.java:451) at com.eteks.sweethome3d.io.HomeXMLHandler.endElement(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:609) at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumen tParser.java:183) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentF ragmentScannerImpl.java:1343) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2786) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragm entScannerImpl.java:510) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:333) at javax.xml.parsers.SAXParser.parse(SAXParser.java:195) at com.eteks.sweethome3d.io.DefaultHomeInputStream.readHome(Unknown Source) at com.eteks.sweethome3d.io.HomeFileRecorder.readHome(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$32.call(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$32.call(Unknown Source) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745)
Reading this forum thread makes me suspect this may be due to the new file format, so I thought you'd appreciate the report. I can send you my file if that helps.
