Re: Export to HTML5 plug-in
Sorry for this issue that seems to happen only with the Mac App Store version. In case you didn't know, you could also use Sweet Home 3D JS Viewer directly with your SH3D file (save and compress it to get a smaller file if needed).
España
I try to put in a wordpress page but I don't know how to do it. In my computer works, I upload to the server and appear page not found, I try to put like html code in a wordpress page and don´t work look like uploading all the time. Do you know what I can do?
Do you mean that you wonder if the 3D viewer would be able to generate such images or view existing images (like the sky texture but also with the other half on ground side)?
Yes I wonder if the online 3D viewer would be able to show the panorama from the images created in Sweet Home 3D (spherical lens). If there is a solution to see these panoramas directly in the 3D view of Sweet Home 3D with a fully spherical sky, why not?
EnkoNyito
United States
Is anyone having crashing issues? I'm using the Mac App Store version with the highly out of date plugin which I think is causing the crash. Every single time that I export to HTML, the freaking app crashes. Rebooting doesn't help. Renaming the file and opening doesn't do anything. I've GOT to get this exported for my shed builder for a custom quote. Any one know what I could do to keep this bloody thing from crashing? Crash report here: https://pastebin.com/bvYpLvWw
This must be due to sandbox restrictions in Mac App Store applications. I recently saw the same issue in the YafaRay plug-in where I programmed a different way to save a file. It should also work for the Export to HTML5 plug-in. I'll post an update soon.
Is there a way to force the "virtual Visit" as the default view (as opposed to the aerial view) ? Sorry if the information is already somewhere, i couldn't find anything.
Thanks for your help and big thanks to the creator of this plugin.
United States
Thank you for the reply and while that may be A SOLUTION it's not THE SOLUTION. I'm having the exact same issue for both versions; the MAS and the Open Source version. Now, I'm getting THIS bloody error and I'm about to pull my hair out. I need to get this plan to the construction crew!!!!
PS - And before y'all go blasting me about this being open source software and freely downloadable and I shouldn't get irritated, well, I donate regularly and have purchased the MAS version in an effort to help the project and I really need this software to work as expected.
And if you donate today to the WHO, tomorrow we all have the vaccine against corona...
I can understand you, such problems are annoying. But if it were that easy, you wouldn't have the problem at all.
Pascal
