There's nothing to change the elevation of the visitor, but adding buttons for that should be quite easy. Just need some documentation to explain how to do it!
Re: Export to HTML5 plug-in
Pinch!
Yes, well, I did try pinching, but cannot get it to work with either Opera or Chrome - pinching inside the canvas just rotates (and otherwise zooms the entire page). Under Win 8.1 pinching seems to zoom the page, regardless how much I try to focus inside the canvas. Maybe just me or my setup. Will try further. Either way, I suspect it is possible that I am not the only one having trouble (I hope), so buttons may be a good idea for a future release, just in case :-)
I'm currently looking into home automation, what hardware systems there are and what GUIs they offer. If there was a possibility to add triggers to lamps, furniture etc in SH3D that can call external scripts in the HTML export and also get notified on changes (e.g. light switches) you'd have a kick-ass home automation GUI that no other can beat :)
I just released the version 1.0 of the Export to HTML5 plug-in, with a little add-on to the Free 3D models page as a surprise. Along with the Java source code included in the plug-in file, I published the source Javascript files in the new SweetHome3DJS project and generated the JSDoc of the API if you're interested. swave, you may access to the information of a home through this API, and even... modify a loaded home. Just retrieve the HomePreviewComponent instance returned by viewHome and have fun! For your information, the API of the Javascript classes is some kind of subset of the Java API of Sweet Home 3D, but using a script language here will help to program small additional features much faster. For the 3D view itself, the main missing feature might be an API to manage picking, but that should come soon.
Okh, I added in this release the navigationPanel parameter that lets you display the navigation arrows or completely customize them if needed. I also added the viewerControlsAdditionalHTML parameter to customize the zone below the 3D view, for example to add Forward and Backward buttons displayed in the gallery examples only under Android, where pinch isn't supported in Javascript yet!
Note that the Javascript "minified" core-min.js, geom-min.js, triangulator-min.js, viewhome-min.js and viewmodel-min.js files were renamed with a dot instead of an hyphen and navigationPanel.png was added. So be sure to clean your lib folder if you deploy this new version, and update the <script> tags that reference these files if needed. See you soon for more information about this release
Sorry, during my last tests of the viewer, it looks like I forgot IE 11 where it fails (under Windows, I mainly use Edge). Therefore, I had to release the new version 1.0.1 to fix this issue. Only Javascript files were modified. Thanks okh for reporting the issue.
For your information, I just released a new version 1.0.2 that fixes various issues, mainly for developers interested to use SweetHome3DJS API.
Tonight, the version 1.0.3 fixes a bug in the plug-in that could generate reduced images with a wrong color profile in the exported home. If you saw some issues on the textures of your home while viewing it in a browser (too dark images or mixed with a pink color), then you should export it again with this new version. Otherwise, this update fixes also an issue on selection management in the Javascript code, but that sould interest you only if you started to use SweetHome3DJS API.
The last version 1.1, announced also in this article of the blog, fixes bugs on the position of the navigation panel when the user scrolls in the window where a canvas is displayed, brings a better management of the canvas when the window is resized, and also brings the new method getClosestItemAt in HomeComponent3D class to handle picking. In the current version, all objects in a home are pickable except the transparent parts of doors or windows, allowing you to pick objects visible through window panes!
Once I found out how to run the plug-in on a headless web server (as explained here), I also decided to add a new service on sweethome3d.com that lets registered users upload their .sh3d files on the web server to view them in 3D, like in this example. This should help the ones among you who wants to show their designs without the need to have their own web server or even run the Export to HTML5 plug-in on their computer. At the moment, this service allows .sh3d files with a maximum size of 15 MB which should be enough for small to medium designs. Don't forget to save and compress your .sh3d files with Sweet Home 3D before uploading them, to avoid useless upload traffic and to be able to upload larger designs.
[Edit 1 times,
last edit by Puybaret at May 5, 2016, 8:35:42 PM]
