Unfortunately I don't have the build environment for this...@Keet
In project SweetHome3DJS, you should remove the lines 375 to 391 in build.xml and run Ant viewerBuild target.
Export to HTML5 plug-in
This topic has been viewed 5091142 times and has 152 replies
Re: Export to HTML5 plug-in
I can send them to you if needed. If it's for debugging purpose, you should know that debuggers in browsers let you unminify code. It won't rename local variables to their original name but it's most of the time enough to find bugs.
If you could I would very much appreciate it. You have my email. Thank you in advance!I can send them to you if needed. If it's for debugging purpose, you should know that debuggers in browsers let you unminify code. It won't rename local variables to their original name but it's most of the time enough to find bugs.
Who is online
