Re: Export to HTML5 plug-in
You can modify the generated HTML file to add all the scripts you want. The API of the JavaScript code exported from this plug-in is a subpart of Sweet Home 3D JS API. HomePreviewComponent object returned by viewHome function will let you access to all the data of the loaded home, with the ability to hide furniture objects with their setVisible method.
I tried the embed-sweethome3d plugin and inserted the short code, I got the message: "Error: ReferenceError Ground3D is not defined" at run time.
Thank you for the wordpress plugin. However, I got an error while viewing the page ReferenceError Ground3D is not defined There is no problem running the exported viewHome.html directly on the site. Embedded in the wordpress website article will be an error
This has been raised by several people and has not been responded to. I tried Export to HTML5 plug-in 1.4 and 1.6 both are the same. The ZIP used is inside the ZIP
Translated with www.DeepL.com/Translator (free version)
If Ground3D is not defined, it must mean that some JS files are missing or have been truncated. Did you check in the JS debugger of your browser what JS files are available?
JS debugger I don't know how to use. But the Export to HTML5 plug-in exported viewHome.html is working. The same site and browser, the wordpress SH3D plugin doesn't work ================= document.registerElement is deprecated and will be removed in M73, around March 2019. Please use window.customElements.define instead. See https://www.chromestatus.com/features/4642138092470272 for more details. module.exports.registerElement @ aframe-v1.0.4.min.js?ver=5.9.1:901 107.../utils/ @ aframe-v1.0.4.min.js?ver=5.9.1:899 o @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 108../a-entity @ aframe-v1.0.4.min.js?ver=5.9.1:901 o @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 112.../../lib/three @ aframe-v1.0.4.min.js?ver=5.9.1:909 o @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 155.../package @ aframe-v1.0.4.min.js?ver=5.9.1:995 o @ aframe-v1.0.4.min.js?ver=5.9.1:1 r @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 (anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1 aframe-v1.0.4.min.js?ver=5.9.1:995 A-Frame Version: 1.0.4 (Date 2020-02-05, Commit #2b359246) aframe-v1.0.4.min.js?ver=5.9.1:995 three Version (https://github.com/supermedium/three.js): ^0.111.6 aframe-v1.0.4.min.js?ver=5.9.1:995 WebVR Polyfill Version: ^0.10.10 sweethome3dembed-public.js?ver=1.0.0:14 ReferenceError: Ground3D is not defined at HomeComponent3D.createGroundNode (viewhome.min.js?ver=1.0.0:20) at HomeComponent3D.createSceneTree (viewhome.min.js?ver=1.0.0:20) at HomeComponent3D.createComponent3D (viewhome.min.js?ver=1.0.0:20) at new HomeComponent3D (viewhome.min.js?ver=1.0.0:20) at HomePreviewComponent.createComponent3D (viewhome.min.js?ver=1.0.0:20) at Object.homeLoaded (viewhome.min.js?ver=1.0.0:20) at HomeRecorder.parseHomeXMLEntry (viewhome.min.js?ver=1.0.0:20) at Object.zipReady (viewhome.min.js?ver=1.0.0:20) at XMLHttpRequest.<anonymous> (viewmodel.min.js?ver=1.0.0:20)
Belgium
Hi all,
Ok, I found it, I was searching for answers but didn't look at html code, sorry for the question.
In the <head><style type="text/css"> of viewHome.html file:
<style type="text/css"> /* The class of components handled by the viewer */ .viewerComponent { } /* To display the viewer in full screen, uncomment the 3 following styles */
---------------------------------------- Dubito, ergo sum
Mobo: ASUS TUF GAMING Z690-PLUS CPU: Core i9-12900K RAM: 32 GB DDR4 3200 Ghz GPU: MSI GeForce GTX 1660 SUPER 6G OS: Win 11 Pro 3D: SH3D 6.6.1 and Blender
Germany
Hello.
I have Firefox for IOS on my iPhone 11 and this is my default browser. If I open the link to my plan in Firefox (hosted on an external server), I get an "Error: Script Error" have to click "OK" about 60 - 70 times, otherwise Firefox does not work anymore. In Safari it works as expected.
