Total posts in this thread: 153
Posts: 153   Pages: 16   [ Previous Page | 7 8 9 10 11 12 13 14 15 16 | Next Page ]
Previous Thread This topic has been viewed 3486490 times and has 152 replies Next Thread
Re: Export to HTML5 plug-in
Hello Matthias,
Reducing the total file size is a good way to help it work, but it could also be due to the size or the complexity of a 3D model you're using, even if I'm quite astonished you experienced this bug also on a Windows computer.
As the 3D model of invisible furniture isn't exported, you could try to export again your home after hiding its largest models (the 3D model size of each piece of furniture can be displayed in furniture list by choosing Furniture > Display column > Model size menu item). Once it works, try to find the culprit by showing the invisible furniture one after the other.
[Jul 19, 2021, 1:07:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mba089
Germany
Hi Emmanuel,
Thank you so much for the quick response!
I solved it and got it working thanks to your Tipps, yet I still have no clue what the Problem was..
In the end it now works with a filesize of 28MB, I only had to leave out one single model (a carpet - nothing special). I identified it by deleting several groups after each other and then trial and error…
Anyway, really happy that it works now and thanks again - also for this amazing plug-in!
Kindly Matthias
[Jul 20, 2021, 8:49:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
imortalreis
Hello,
Is it possible insert some option to the user change the items?
Example: checkboxes inputs that remove/add bed + tv
Thank you
[Feb 8, 2022, 4:42:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can modify the generated HTML file to add all the scripts you want.
The API of the JavaScript code exported from this plug-in is a subpart of Sweet Home 3D JS API. HomePreviewComponent object returned by viewHome function will let you access to all the data of the loaded home, with the ability to hide furniture objects with their setVisible method.
[Feb 8, 2022, 5:34:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Hey Joe!
Perhaps this one can solve your problem: https://wordpress.org/plugins/embed-sweethome3d/
I tried the embed-sweethome3d plugin and inserted the short code, I got the message: "Error: ReferenceError Ground3D is not defined" at run time.
Thank you for the wordpress plugin.
However, I got an error while viewing the page ReferenceError Ground3D is not defined
There is no problem running the exported viewHome.html directly on the site. Embedded in the wordpress website article will be an error
This has been raised by several people and has not been responded to.
I tried Export to HTML5 plug-in 1.4 and 1.6 both are the same. The ZIP used is inside the ZIP
Translated with www.DeepL.com/Translator (free version)
[Feb 27, 2022, 2:55:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
The system environment is
WINDOWS SERVER 2019
WordPress 5.6
Nginx 1.21.1
MySQL 8.0.25
PHP-7.4
[Feb 27, 2022, 3:01:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If Ground3D is not defined, it must mean that some JS files are missing or have been truncated.
Did you check in the JS debugger of your browser what JS files are available?
[Mar 9, 2022, 2:31:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
JS debugger I don't know how to use.
But the Export to HTML5 plug-in exported viewHome.html is working. The same site and browser, the wordpress SH3D plugin doesn't work
document.registerElement is deprecated and will be removed in M73, around March 2019. Please use window.customElements.define instead. See https://www.chromestatus.com/features/4642138092470272 for more details.
module.exports.registerElement @ aframe-v1.0.4.min.js?ver=5.9.1:901
107.../utils/ @ aframe-v1.0.4.min.js?ver=5.9.1:899
o @ aframe-v1.0.4.min.js?ver=5.9.1:1
(anonymous) @ aframe-v1.0.4.min.js?ver=5.9.1:1
108../a-entity @ aframe-v1.0.4.min.js?ver=5.9.1:901
112.../../lib/three @ aframe-v1.0.4.min.js?ver=5.9.1:909
155.../package @ aframe-v1.0.4.min.js?ver=5.9.1:995
r @ aframe-v1.0.4.min.js?ver=5.9.1:1
aframe-v1.0.4.min.js?ver=5.9.1:995 A-Frame Version: 1.0.4 (Date 2020-02-05, Commit #2b359246)
aframe-v1.0.4.min.js?ver=5.9.1:995 three Version (https://github.com/supermedium/three.js): ^0.111.6
aframe-v1.0.4.min.js?ver=5.9.1:995 WebVR Polyfill Version: ^0.10.10
sweethome3dembed-public.js?ver=1.0.0:14 ReferenceError: Ground3D is not defined
at HomeComponent3D.createGroundNode (viewhome.min.js?ver=1.0.0:20)
at HomeComponent3D.createSceneTree (viewhome.min.js?ver=1.0.0:20)
at HomeComponent3D.createComponent3D (viewhome.min.js?ver=1.0.0:20)
at new HomeComponent3D (viewhome.min.js?ver=1.0.0:20)
at HomePreviewComponent.createComponent3D (viewhome.min.js?ver=1.0.0:20)
at Object.homeLoaded (viewhome.min.js?ver=1.0.0:20)
at HomeRecorder.parseHomeXMLEntry (viewhome.min.js?ver=1.0.0:20)
at Object.zipReady (viewhome.min.js?ver=1.0.0:20)
at XMLHttpRequest.<anonymous> (viewmodel.min.js?ver=1.0.0:20)
[Mar 10, 2022, 12:41:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KelvinUceta
Belgium
Hi Gildaniel,
Did you succeeded to get the viewer in full screen? Reading through this post isn't quite clear and if did how did you proceeded?
Also tried "SweetHome3DJSViewer-6.4" but I can't get it.
Thx in advanced,
Kelvin
Dubito, ergo sum
Mobo: ASUS TUF GAMING Z690-PLUS
CPU: Core i9-12900K
RAM: 32 GB DDR4 3200 Ghz
GPU: MSI GeForce GTX 1660 SUPER 6G
OS: Win 11 Pro
3D: SH3D 6.6.1 and Blender
[Dec 17, 2022, 12:54:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KelvinUceta
Belgium
Hi all,
Ok, I found it, I was searching for answers but didn't look at html code, sorry for the question.
In the <head><style type="text/css"> of viewHome.html file:
/* The class of components handled by the viewer */
.viewerComponent {
/* To display the viewer in full screen, uncomment the 3 following styles */
Dubito, ergo sum
CPU: Core i9-12900K
OS: Win 11 Pro
[Dec 18, 2022, 6:27:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
