Picture imported furniture does not show in library
When I import a furniture, I get only a white square in the library without showing the imported object. I can integrate it in my drawing, but how can I make it visible in the library, when I want to have an overview of objects.
Re: Picture imported furniture does not show in library
Try this: Select the model in the furniture list (top-left window) Select Modify Click Next until you arrive at the last screen Rotate the image of the model a bit. Click Finish.
it worked a couple of times, and then it didn't. But then I discovered the reason: do not click on 'finish' too soon. Simple yes, you just have to know. thank you for your answer.
