Total posts in this thread: 4
Previous Thread This topic has been viewed 4528 times and has 3 replies Next Thread
schnesim
Room with roof pitch won't show ceiling
I uploaded an example: http://ul.to/u6attfyz
The ceiling should be visible in bright purple but instead one can see the sky. What am I doing wrong?
Regards
Simon
[Feb 25, 2016, 12:58:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Room with roof pitch won't show ceiling
The ceiling is there, but sloping up at low level.
In a room with many roof corners - like a loft - the automatic ceiling does not (always) work correctly as it tries to hook up with the top of the walls (well, think of it like that).
For me, the best way to draw that kind of loft, would be not to use ceilings, but use a roof (on a new level) instead. Still, it is fully possible to make the ceilings alone.
In your file, the ceiling gets extra confused because you have double walls several places (short sides) - they are on top of eachother, so they are not that easy to see - and your walls do not all go in the same direction and are not connected.
Try this approach:
- draw the walls like a rectangle in one sweep clockwise so they are all connected,
- split the walls and put the joints in accurate positions,
- draw three separate rooms accurately between the wall joints.
Tried that on your file - removing the extra walls, make them all go clockwise and joining them, then the three room approach worked to display ceilings.
[Feb 26, 2016, 8:55:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Take a look at this file: roofless no more
Then take a look on the Documentation page: there's a tutorial on sloping roofs.
The trick: each section of the roof needs its own "room".
[Feb 26, 2016, 9:00:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
schnesim
Thank you guys :)
I created the room with walls first and despite trying to be very carefull, as I ran into trouble with double walls before, somehow I messed it up.
I just re-created the room from scratch, this time room first, walls later, then adding the slopes and it worked like a charm.
I will also keep the trick with a room for each roof section in mind for more complex scenarios.
[Feb 26, 2016, 10:29:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
