Total posts in this thread: 4
Previous Thread This topic has been viewed 6784 times and has 3 replies Next Thread
james67210
Visibilité du toit / hidden roof
-- FR --
Bonjour,
J'ai un problème avec le rendu d'une toiture.
En effet, il n'apparaît que sous certains angles. Impossible d'avoir le toit en entier... Quel est le problème ?
Merci
-- EN --
I have a problem with rendering the roof.
Indeed , there appears to under CERTAIN angles. Could not have the entire roof ... What's The Problem ?
Thank you
[Feb 10, 2016, 3:23:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Visibilité du toit / hidden roof
It looks like the triangles that you use are single sided and the visible side is oriented towards the ground.
When you import them, you should select the option Invert back and front faces at the second step of Furniture import wizard. You could also use some double sided triangles or simply use this simple triangle that you'll resize.
[Feb 10, 2016, 5:57:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
james67210
Thanks for your reply.
I tried several times, but nothing to do, the result is not good .
At first I put rooms with just the visible top.
I'm lost.
[Feb 15, 2016, 3:15:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want, send me the file and I'll have a look at it.
[Feb 15, 2016, 4:35:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
