Total posts in this thread: 2
Previous Thread This topic has been viewed 6286 times and has 1 reply Next Thread
ACB
AUSTRALIA
smile Door -2-
Door -2- under Doors and windows
shows a framed door
are the AUTOMATIC Sizes with door Frame or just the door?????
please help
Andrew
[Dec 17, 2015, 5:03:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
JUGGERNAUT
Re: Door -2-
THE DOOR AND FRAME ARE ONE OBJECT.
IF YOU PLACE A FRAME FIRST, AND THEN A DOOR INTO YOUR FLOOR PLAN, YOU NEED TO GROUP THE TWO OBJECTS TOGETHER.(SELECT BOTH THE OBJECTS, THEN RIGHT CLICK AND SCROLL DOWN UNTIL YOU SEE "GROUP", THEN CLICK. THIS WILL COMBINE BOTH OBJECTS AS ONE.....SIMILAR PRINCIPLE AS IN POWERPOINT). ONLY THEN CAN YOU SIZE IT AS ONE OBJECT, ELSE YOU NEED TO SIZE INDIVIDUALLY.
[Dec 18, 2015, 6:50:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
