Previous Thread This topic has been viewed 3382 times and has 2 replies Next Thread
bAdLucK
Print only a single room on a floor
Hi everybody,
is there an easy solution (meaning not deleting all other rooms) to print only a single room? I have drawn the whole 1st floor of a house but in order to discuss things with the bath-guys, i would love to print only the bathroom. So far i always do a printscreen and copy paste it into paint and print it from there, which is obviously not the greatest solution imaginable. :D
I didnt find any options in the SH3d itself and also couldnt find anything in this forum via the search option (maybe wrong keywords?).
Thanks for your help!
(I hope i'm in the right Subforum)
[Nov 3, 2015, 10:23:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: Print only a single room on a floor
You could select everything in the bathroom using the shift key after selecting the first object to select more objects. Once you have everything selected, right click and select Copy.
Then open a new home and right click and select paste.
It can be a little tricky doing this if you have something on top of something else.
You can also drag a box around the bathroom to select all.
You could also delete everything but the bathroom and make sure you save it as a new file so you don't lose everything.
Hawk
[Edit 2 times, last edit by HawkDawg at Nov 3, 2015, 11:25:08 PM]
[Nov 3, 2015, 11:24:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Instead of a print screen, you could also select what you want to show, copy it and paste it in a drawing tool or even a word processing software (this might not work under Linux).
You could also separate this room in a first level at the same elevation, so when you select that level, only that room would be shown (see attached example).
Attachment BathroomInSeparateLevel.sh3d (953228 bytes) (Download count: 359) (Home with two levels at same elevation to separate a room)
[Edit 2 times, last edit by Puybaret at Nov 4, 2015, 9:20:00 AM]
[Nov 4, 2015, 9:18:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
