Re: Print only a single room on a floor
Instead of a print screen, you could also select what you want to show, copy it and paste it in a drawing tool or even a word processing software (this might not work under Linux). You could also separate this room in a first level at the same elevation, so when you select that level, only that room would be shown (see attached example).
BathroomInSeparateLevel.sh3d
(953228 bytes)
(Download count: 246)
(Home with two levels at same elevation to separate a room)
[Edit 2 times,
last edit by Puybaret at Nov 4, 2015, 8:20:00 AM]
[Nov 4, 2015, 8:18:02 AM]
[Link]
