Total posts in this thread: 20
Posts: 20   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 11713 times and has 19 replies Next Thread
Re: Crash on clicking preferences
Ok, then what did you mean by "it doesn't work"?
I also wonder if the -D... option should rather be placed before -jar option. Can you try?
[Nov 20, 2015, 8:38:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
This is odd, it did only show the splash screen. Today that command starts the whole application but crashed when opening Preferences.
Changing the arguments order as you said, makes Preferences work, thanks!
java -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false -jar /usr/share/java/sweethome3d.jar
[Nov 21, 2015, 3:42:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wood
same problem (crash on preferences) on Linux Debian (BunsenLab). Sorry but I did not understand how did you solved, I installed the Debian package and then I tried the version on SourgeForge.
The fact is that Java is out of my knowledge and probably is just me that do not understand what you are talkking about.
[Jan 4, 2016, 2:32:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
Just go to the download page http://www.sweethome3d.com/download.jsp download the Web Starter http://www.sweethome3d.com/SweetHome3D.jnlp and open it with javaws
[Jan 7, 2016, 12:11:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz, the JNLP file you referenced won't solve wood's problem.
It should rather be http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp
[Jan 7, 2016, 8:14:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wood
Thanks for replay. I am not using Sweet Home 3D with Java Web Start (do not have Java 6 installed, should I?). So I guess goetz answer did not fit my problem. And the file indicated by Puybaret is a .jnlp, so (for what I understood) is suppose to be used by a Java Web Starter (same story I guess).
[Jan 9, 2016, 3:23:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
goetz
Puybaret, you are right!
wood, just add the checkOffScreenSupport option when invoking sweethome3d. Your path may defer. dpkg -L sweethome3d will show you where the sweethome3d.jar file is. It maybe:
java -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false -jar /usr/share/sweethome3d/sweethome3d.jar
[Jan 9, 2016, 6:50:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wood, the only other solution is to add the option:
after the word "java" in the SweetHome3D script available in the downloadable installer.
Then, the last line of the script
exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java -Xmx1024m ...
should become:
exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false -Xmx1024m ...
(be sure to add no line returns)
[Jan 9, 2016, 7:15:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wood
Thanks again. It works (of course) now. Sorry if I was a little slow understending.
[Jan 12, 2016, 9:09:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bert.struik
Canada
Had this problem with version 5.1 on Ubuntu 14.04. Used the suggested java fix line from the FAQ. Then I could change preferences. A side effect was that I could not longer delete walls. Removed the java line and then I could delete a wall again.
[Jan 21, 2016, 5:14:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
