Total posts in this thread: 7
Previous Thread This topic has been viewed 7787 times and has 6 replies Next Thread
SKYFLIGHT
problem with lighting effects
Hello, again I remind you that do not speak English and this message performed with google translator.
I'm trying to make a disco, but I find the lighting problem.
I would like to know so I can make lights that have projection to give the effect of a disco.
From already thank you very much
[Jun 12, 2015, 9:58:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: problem with lighting effects
I sent you a file I made a few years ago.
Maybe it helps.
[Jun 13, 2015, 9:52:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
santbose
India
Hi Hansmex can you upload the same in Sourseforge or in the forum for others to use if they are interested. Thanks in advance.
[Jun 15, 2015, 8:20:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I can, but I won't.
I've sent the file to the email address in your profile.
[Jun 15, 2015, 12:10:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ni_cola79
Italia
Hello to all. I'm new to the forum , but not the program ..
I was wondering if I could get myself some more information about the problem in question .
And again, if there is ' some function ' which decreases the light in a particular room .
Thank you in advance.
[Jul 27, 2015, 10:47:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Short answer: yes, disable "Add ceiling lights " when rendering, and add lightsources to each of the rooms in the plan. Each light source can be dimmed in properties.
Long answer: When you render a photo or video, the light comes from several sources:
1) You will get sunlight according to the time of day (and day of the year). This will change according to the clock and date settings.
2) You can get simple interior illumination with an option to "Add ceiling lights " in "Create photo / video " menus.
3) But you can also add light sources in your plan: see the furniture catalogue and look for "Lightsource" (Incandescent, Fireglow, Red, White etc). These are invisible lamps that can be placed around in the rooms, and their strength can be adjusted in the properties.
4) In addition there are models with specific SH3D light source properties (like this) which can be dimmed just like the light sources in the catalogue. (More info - see e.g.thread 4765). ok
[Jul 28, 2015, 10:38:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DonutGa
Mexico
biggrin Re: problem with lighting effects
Hi Hans , I read this, and also need the file , as did also a disco - bar , but failed to lighting effects , you could send the file by mail? Thank you
[Oct 12, 2015, 1:15:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
