Total posts in this thread: 116
Posts: 116   Pages: 12   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 1420789 times and has 115 replies Next Thread
YGYL
Re: Sweet Home 3D 5.0
Now,with Add point to room Function. I recommend Added a new feature to hollow room.
because create room is very important, The simplest way to establish basic parts.but the existing feature is too cumbersome.Not directly hollow.
I recommend 3 shortcut keys. add points,del point,hollow point.
When the hollow-point in the room range, when the hollow room!
Original Picture
[May 18, 2015, 2:42:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
will you include Add points to room to the Plan top menu?
No, because it would require to introduce a new kind of selection that would let the user select a point in the plan without losing the current selected room.
I get this feeling that future use of SH3D will rely more and more on the right-click context menus.
This is the main reason why these new Add point to room and Delete point from room menu items didn't appear yet. A good user interface should make available all the possible actions in the main menu, but as said previously, it's almost impossible for these items as well as the Select object / Toggle selection menu to appear elsewhere than the contextual menu, because they need a point.
You may like contextual menus, but keep in mind that many users are not used to it (mainly Mac OS X users), and those people might completely ignore that these features are available.
Maybe even the download version should move in the direction of the online version, with no (or optional) top menu (with some more toolbar buttons, of course)
The Online version doesn't come with a menu bar because it's not common to have one in such a part of a web page. But the more I think about it, the more I want to add an option in the Online preferences that will let the user show this menu bar (after all, Java makes it possible easily).
Keep in mind that the menu can be seen like a mini user's guide that people explore to learn how to use a software. wink
YGYL, thanks for your suggestion about "hollow point" but I have no idea about what you mean! sad
[May 19, 2015, 8:07:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Still no problems with 5beta. Points taken.
..it's almost impossible for these items as well as the Select object / Toggle selection menu to appear elsewhere than the contextual menu, because they need a point.
Quite, and I like the logic of your approach. Still, life also moves on, it is not that long ago that the Unix/X interface was designed for three mouse buttons, Win for two, and Mac for one. While many users may not be used to context menus, they work so well and are so easy to use in SH3D that I think many users would find exploring them worth while.
And this little rant, I suppose, is just a sign that I really cannot find anything to complain about in 5 beta smile
OK
[May 19, 2015, 2:17:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
The beta has been very stable -- which is a good thing, as I mistakenly managed to open *and* save a current project using it.
Some observations:
o The improved Collada import is much appreciated.
o The warning about large textures works fine. Now can I have a 'preferences' option to disable it? :)
o The 'modify object in group' function is probably going to be the biggest productivity improvement [so far] in 5.0 -- a bit surprisingly, actually, as I'd never thought it was much of an imposition to ungroup/modify/group. But then I sorted furniture alphabetically, and groups started ungrouping non-consecutively....
Unfortunately, the function isn't quite ready for prime-time, I fear. I've found two problems: First if you expand a group and select one of its components, you can't always move from object to object correctly. That is, using up- or down-arrow from one item to the next doesn't work; focus skips randomly among the items, and some items sometimes can't be selected at all.
Second -- and this is harder to quantify -- but it appears actions taken against one item within a group may sometimes be applied to all. (Or maybe I was just doing something unsupported.) In brief, in one plan I have five boxes representing glue-lam beams arranged vaguely like an octothorp (i.e., pound sign, number sign, hashtag) and grouped together. Noticing one wasn't aligned quite correctly, I expanded the group, clicked on the component in question, and used the arrow keys to nudge it into alignment. Doing so causes the other items to shift -- but seemingly not in step with the one moved. I replicated the effect a number of times, but I couldn't discern if all items in the group shifted the same amount or if the amount shifted remained the same. (Again, this might be outside the intended scope of the function -- that is, selecting an item and then using the arrow keys to modify; if so, though, the documentation should reflect this.)
I haven't tried the other modifications, yet.
Oh, BTW, I'm still using XP on this machine, so before I could do anything I had to increase the stack to 1024mb -- which worked just fine.
Maz
[May 20, 2015, 2:48:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
santbose
India
When would the downloadable version of SH3D 5.0 launched? Just waiting for the same egerly.
[May 20, 2015, 9:49:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
smile Re: Sweet Home 3D 5.0
I have no response problem. I was raised hopes.
I hope to have more of a feature on the new features.
I want this
But, do not support direct hollow draw this
To do this you must draw.Too cumbersome.
If you have hollow room function just fine.can save a lot of steps
[May 21, 2015, 4:16:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Do you mean to be able of create a room which you can manage and from which you can get info like the area, while it remains invisible (white) in the plan instead grey?
I speak of the plan only because in the 3D view you can simply uncheck the "show floor" and "show ceiling" checkboxes, but certainly it cannot be "hidden" in the plan.
[May 21, 2015, 9:11:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I think what is meant is a "room" that surrounds an empty space.
Example 1:
You have a house, and you want to add a green surface around the house to simulate a grass patch. You would then need something as in the example. I draw something like that quite often for basic landscaping of gardens, garden paths, etc.
Example 2:
You have a house with a patio. The patio is covered with tiles/paving, but in the centre there is a grass/garden patch.
[May 21, 2015, 10:07:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
The 'paste style' function works well and is *much* appreciated.
[May 25, 2015, 10:20:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Beta 2 brings... baseboards smile
The room modification pane and wall modification pane were modified to let you select the baseboard you want on the walls around a room, or on each side of a wall.
You can add a baseboard along straight or round walls, choose their height, their thickness, their color/texture or use the same one as the color/texture used for their wall side. Baseboards are cut by doors and windows that intersect the wall along which they are set (actually, baseboards are computed more or less as small walls in the 3D view). Their profile can be only rectangular.
Objects with no elevation are magnetized along baseboards sides instead of walls sides when they are moved around. As soon as their elevation is greater than zero, they will be magnetized along walls sides without taking into account its baseboards.
Baseboards are not drawn in the plan. If ever you think they should be drawn, please give your advice about how they should be represented and why. Maybe I'll change my mind...
One last thing, you can also use baseboard to cover a part of the wall with an other color or texture if you set a big height. That should make it easier to add tiles on top of kitchen cabinets or around a bath.
Do you use so many big textures?
The 'modify object in group' function [...] isn't quite ready for prime-time, I fear. I've found two problems: First if you expand a group and select one of its components, you can't always move from object to object correctly. That is, using up- or down-arrow from one item to the next doesn't work;
I paid attention to reprogram up dans down arrow keys to be able to select groups and items in groups, and then select items in previous or following groups, but you seem to have found a case I forgot. Could you test this feature again and detail how to reproduce the issue you encountered?
I remember I experienced this behavior at a moment, but thought I fixed it correctly. Please, detail steps by steps how to reproduce this issue with a small example using the current beta.
I generally don't release installers for beta versions. If you're a programmer, you can download the source code from CVS and build one yourself.
[May 25, 2015, 7:01:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
