Re: Sweet Home 3D 5.0
YGYL, thanks for your tests
1.fonts in 3D display too Fuzzy,Especially when a large text size.
The text is managed in 3D with a texture image that contains the text and is 512 pixels wide at max. I could use a larger size but fear loss of performance... But if needed this trick is still working.
2.Background coordinates plus or minus is wrong .
No, it's correct. X and Y are the coordinates of the origin of the plan in the image, not the coordinates of the top left point of the image in the plan. If the Chinese translation of the wizard isn't correct, feel free to propose a better one.
Still to come across problems with the new features. So far everything works as expected (or better...)
Just wondering, will you include Add points to room to the Plan top menu? I see reasons not to. But if not, I get this feeling that future use of SH3D will rely more and more on the right-click context menus. Which I guess is good. But maybe the context menus should be emphasised more strongly in FAQ/tutorials. Maybe even the download version should move in the direction of the online version, with no (or optional) top menu (with some more toolbar buttons, of course)... ok
Now,with Add point to room Function. I recommend Added a new feature to hollow room. because create room is very important, The simplest way to establish basic parts.but the existing feature is too cumbersome.Not directly hollow.
I recommend 3 shortcut keys. add points,del point,hollow point. When the hollow-point in the room range, when the hollow room!
No, because it would require to introduce a new kind of selection that would let the user select a point in the plan without losing the current selected room.
This is the main reason why these new Add point to room and Delete point from room menu items didn't appear yet. A good user interface should make available all the possible actions in the main menu, but as said previously, it's almost impossible for these items as well as the Select object / Toggle selection menu to appear elsewhere than the contextual menu, because they need a point. You may like contextual menus, but keep in mind that many users are not used to it (mainly Mac OS X users), and those people might completely ignore that these features are available.
The Online version doesn't come with a menu bar because it's not common to have one in such a part of a web page. But the more I think about it, the more I want to add an option in the Online preferences that will let the user show this menu bar (after all, Java makes it possible easily). Keep in mind that the menu can be seen like a mini user's guide that people explore to learn how to use a software.
YGYL, thanks for your suggestion about "hollow point" but I have no idea about what you mean!
Still no problems with 5beta. Points taken.
..it's almost impossible for these items as well as the Select object / Toggle selection menu to appear elsewhere than the contextual menu, because they need a point.
Quite, and I like the logic of your approach. Still, life also moves on, it is not that long ago that the Unix/X interface was designed for three mouse buttons, Win for two, and Mac for one. While many users may not be used to context menus, they work so well and are so easy to use in SH3D that I think many users would find exploring them worth while.
And this little rant, I suppose, is just a sign that I really cannot find anything to complain about in 5 beta
The beta has been very stable -- which is a good thing, as I mistakenly managed to open *and* save a current project using it.
Some observations:
o The improved Collada import is much appreciated. o The warning about large textures works fine. Now can I have a 'preferences' option to disable it? :) o The 'modify object in group' function is probably going to be the biggest productivity improvement [so far] in 5.0 -- a bit surprisingly, actually, as I'd never thought it was much of an imposition to ungroup/modify/group. But then I sorted furniture alphabetically, and groups started ungrouping non-consecutively.... Unfortunately, the function isn't quite ready for prime-time, I fear. I've found two problems: First if you expand a group and select one of its components, you can't always move from object to object correctly. That is, using up- or down-arrow from one item to the next doesn't work; focus skips randomly among the items, and some items sometimes can't be selected at all. Second -- and this is harder to quantify -- but it appears actions taken against one item within a group may sometimes be applied to all. (Or maybe I was just doing something unsupported.) In brief, in one plan I have five boxes representing glue-lam beams arranged vaguely like an octothorp (i.e., pound sign, number sign, hashtag) and grouped together. Noticing one wasn't aligned quite correctly, I expanded the group, clicked on the component in question, and used the arrow keys to nudge it into alignment. Doing so causes the other items to shift -- but seemingly not in step with the one moved. I replicated the effect a number of times, but I couldn't discern if all items in the group shifted the same amount or if the amount shifted remained the same. (Again, this might be outside the intended scope of the function -- that is, selecting an item and then using the arrow keys to modify; if so, though, the documentation should reflect this.)
I haven't tried the other modifications, yet.
Oh, BTW, I'm still using XP on this machine, so before I could do anything I had to increase the stack to 1024mb -- which worked just fine.
