Total posts in this thread: 116
Posts: 116   Pages: 12   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 1435694 times and has 115 replies Next Thread
YGYL
Re: Sweet Home 3D 5.0
NEW BUG 2 > □
Original Picture
[Jul 16, 2015, 1:24:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's probably the character "²" that is missing in the font you chose.
[Jul 16, 2015, 4:41:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
applause Re: Sweet Home 3D 5.0
If you can ,then not find "²" in the font,specify a default "²" would be better.
[Jul 17, 2015, 2:52:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I wanted to release Sweet Home 3D 5.0 tonight, but can't tag the version in the source code and can't upload installers on SourceForge.net because most of their services have been down for almost one day!
That's why I prefer to host the released files on sweethome3d.com for the moment.
You can download them with the following links:
[Removed old links, go to https://sourceforge.net/projects/sweethome3d/files/SweetHome3D/SweetHome3D-5.0/ to download the files]
Once SourceForge.net will be repaired, I'll upload these files there and will make the release more official on sweethome3d.com.
Thanks for your patience...
[Edit 1 times, last edit by Puybaret at Aug 10, 2022, 11:48:28 AM]
[Jul 17, 2015, 10:58:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you once again for a great job !!
[Jul 17, 2015, 11:03:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As upload service won't still be available on SourceForge.net before a while, I officially released Sweet Home 3D 5.0 files on sweethome3d.com tonight.
Released files will be copied at SourceForge.net, once their service will be back.
Note that the files I released two days ago were updated under the same name at 19:23 CEST on July 19, to fix a bug I found on the visibility of doors and windows in layers lower than the one they belong to. Sorry for any inconvenience redownload may cause.
Thanks for your tests and your great support! smile
[Jul 19, 2015, 11:47:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
From the old version to the present, there has been a translation error
Original Picture
新建墙体厚度(F) change to 新建楼层的楼板默认厚度(F)
[Jul 21, 2015, 2:44:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yancan
Hello Emmanuel,
great piece of software by the way!
Do you have any idea when the portable version of V5.0 will be made available?
Best regards.
[Jul 29, 2015, 4:05:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Probably not before mid August. The missing data are some sh3l additionnal translations that contributors might have difficulties to update because of SourceForge problems with CVS and other repository features.
But you can update the existing portable version 4.6 to 5.0 by yourself: download one of the Linux installers of version 5.0, uncompress it to get the lib/SweetHome3D.jar file it contains, then replace the file with the same name in the portable version with the 5.0 version file you extracted. That's all!
[Jul 30, 2015, 9:49:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yancan
Merci beaucoup pour cette technique d'upgrade manuelle !
Cordialement.
[Jul 30, 2015, 5:55:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
