Need some furniture and other things, please help!
Hello everyone. There are several items of furniture and other things things that I need. I have a short list of things I need, in particular, an octagon-shaped Poker Table, some white, louvered French closet doors, etc. Does anybody know how I can contact someone to make them for me? I've done a search for them, but have been unable to find them. I cannot make them myself. Any help in this would be greatly appreciated.
Re: Need some furniture and other things, please help!
Thanx for the info. I checked out the ones you mentioned, but they don't seem like a file I can use in a sweethome3d house. Am I missing something? If so, please let me know what, and how to go about using them. I have other furniture and some textures I need as well.
In the current version of Trimble 3D Warehouse, you should first click on the image of a model, then click on Download red button to choose KMZ or Collada file format that is supported by Sweet Home 3D.
Said an other way: Don't click on the symbol shown at the bottom left of model images: NO
but click on model images themselves, then click on Download button and choose a file format supported by Sweet Home 3D: YES
Thanx for the additional info. That helped a lot. I did have an issue with some files tho. They showed as KMZ files, but when I tried to install them, sweethome3d said they were not compatible. Any known reason for this? So far I've been able to fine quite a bit of what I was looking for. Will keep looking. One thing I am having a bit of trouble finding is a good texture for dark grey aluminum siding. I already tried one I have. It works, but not very well. Any thoughts where I can find one? Also, since I'm here, can somebody tell me how to add an 8" step up to a room, and add a roof? I haven't figured out how to do this yet. As usual, all help is very much appreciated.
Could you post here the URLs to the KMZ models that caused some problems, please?
As a general rule, I delete the file if it doesn't work. One of the files is a 2012 Mercedes-Benz C63 AMG Sedan by Allabassiry. It says its a KMZ file, but if I try to install it, it says "the format of the chosen model isn't supported". Most of the other KMZ files I've tried have worked OK, but there have been other exceptions also. Unfortunately, I can't tell you which ones for the reason already stated. Will try to let you know of others if they show up. If the above file can be fixed, please let me know. Thanx.
You are right, the Mercedes model you mentioned cannot be imported in SH3D. A variation by another designer (but based on the same model) also cannot be imported. (Using SH3D 4.6 on Windows)
