Previous Thread This topic has been viewed 3934 times and has 9 replies Next Thread
cusa123
Motor de render posible cycles?
Al parecer Amd pudieron parchear correctamente cycles para sus tarjetas. Ahora bien esto es posible trasladarse a sweet home 3d?.Ya que funcionan para Nvidia y Amd? biggrin
[Mar 27, 2015, 12:15:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Motor de render posible cycles?
No estoy seguro si entiendo tu pregunta.
1 - SH3D usa todos los nucleos del processador cuando esta haciendo un render en nivel de calidad 3 o 4.
2 - SH3D no usa la tarjeta video para hacer los renders en ningun nivel de calidad.
[Mar 27, 2015, 7:15:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cusa123
The question is whether there is possibility of adding gpu render cycles?
[Apr 5, 2015, 3:12:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No, that is not possible.
No, no es posible.
[Apr 5, 2015, 8:41:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cusa123
What is required to accept sweet home 3d cycles?
Que es lo que requiere sweet home 3d para aceptar cycles?
[Apr 6, 2015, 12:18:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Podrias escribir un programa de extension que lo haga?
You could write an extension of SH3D that could handle the graphic processor(s)...?
[Apr 6, 2015, 2:46:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cusa123
Dentro de blender vi un proyecto de cycles independiente. Dejame preguntar pero en general, es tipo java extencion la extencion para sh3d?
In blender saw a project of independent cycles. Let me ask but overall is kind java extencion the extention to SH3D?
[Apr 7, 2015, 2:53:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No lo se. Sugiero leer la(s) Guia(s) de Desarrolladores.
I don't know. I suggest you read the Developer's Guide(s).
[Apr 7, 2015, 7:05:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cusa123
Al parecer puede que se interesen en sweet home java,no lo se.
Pero un primer paso para que desarrolladores de blender ayuden es intentando de usar nativamente archivos (.blend) en sh3d. En si es molesto exportar y muchas veces no queda bien si eh visto un cycles externo. Puede ser el complemento que le falta a blender la parte de arquitectura o diseño para 3d casas,edificios,ect.
[Note from moderator: removed French and English versions which didn't mean anything. cusa123, if you don't speak English or French, don't rely on automatic translations for technical subjects]
[Edit 2 times, last edit by Puybaret at Apr 7, 2015, 3:34:15 PM]
[Apr 7, 2015, 3:05:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cusa123
Cycles Standalone Engine
http://blenderartists.org/forum/showthread.ph...s-Standalone-Engine/page2
[Apr 7, 2015, 3:37:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
