Previous Thread This topic has been viewed 7931 times and has 10 replies Next Thread
kurucom
Turkey
Cannot render in level 4 (best)
My computer has:
AMD FX8320 (8 core @ 3.5 GHz)
AMD 280X (3 GB)
16 GB RAM (4x4 GB)
256 GB SSD (Ocz Vertex 4 - only 1 partition and 109 GB empty)
4 TB HDD (Seagate barracuda 7200.14 - only 1 partition and 806 GB empty)
Windows 8.1 64 bit (very stable and has all updates)
Java version 8 update 31 (64 bit)
SweetHome3D.l4j.ini contains 2 lines
-Xmx16384m
-Xms3072m
I am trying to render in best level but cant do it, even small object (fx. only one table in scene)
Level 1, 2 and 3 works fine but on 4 (best level) nothing happens
Sorry for my bad english....
[Jan 30, 2015, 3:22:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Cannot render in level 4 (best)
What does Help --> About say?
Something like:
Java version 1.6.0_45 / 32 bit / 0.6 GB max
[Jan 31, 2015, 10:56:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kurucom
Turkey
Something like:
Help -> About Says:
Java versiyonu 1.6.0_45 / 64 bit / 14,2 GB max
[Jan 31, 2015, 2:05:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Where did the table come from? Wouldn't you have used a too large image as texture somewhere?
[Feb 2, 2015, 2:47:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kurucom
Turkey
I dont remember, I have too much objects imported from Sketchup, 3DMax etc....
But I am trying to render what I seen in this forum happens nothing.
I am creating new file with only one table it hapens nothing to.
[Feb 2, 2015, 2:55:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Send me your file if you want. Maybe you encountered a bug.
[Feb 5, 2015, 6:39:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kurucom
Turkey
Sent... Thank you very much...
[Feb 7, 2015, 7:57:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I've been trying your file on my iMac with no issue using -Xmx2250m.
Could you try again with Sweet Home 3D version 4.6 and no SweetHome3D.l4j.ini file?
[Feb 8, 2015, 7:52:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kurucom
Turkey
Finally found the problem
I changed only Language and now everythings work.
Maybe you should check language file.
[Feb 9, 2015, 7:20:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Would you use Turkish localization?
Last week, after releasing the version 4.6, I found a bug that prevented to run the rendering at the best quality with Turkish localization. Correction will be available in the next version. Sorry for the issue. If you prefer to run Sweet Home 3D in Turkish, I can provide a patch if needed. Just open a bug ticket and I'll post the patch there.
[Edit 1 times, last edit by Puybaret at Feb 9, 2015, 3:47:16 PM]
[Feb 9, 2015, 3:24:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
