Total posts in this thread: 42
Posts: 42   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 21742 times and has 41 replies Next Thread
prabath
Re: Need to deploy on Tomcat serer
Hi Pyubaret
I enhanced my application to detect the lines of the Floor plan which is in the grid. I used Boof CV(http://boofcv.org/index.php?title=Main_Page)
libraries to do that. For the moment, it doesn't support all the floor plans. I'm improving the my line detecting algorithm.
But when I deployed the application on server(as a web application) with new feature, it says BoofCV libraries can't be found. I added BoofCV libraries under "otherLibraries" Tag in build.xml file. It
compiles perfectly, but when it runs as a web application , it can't load added Boof CV libs. I would be thankful , if you tell me if there is another way to
add libraries.
Thank You..
[Feb 3, 2015, 5:48:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Hi Pyubaret ...
I think you will help me on this. I'm bit stuck on this
Thank You
[Feb 4, 2015, 5:32:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Manage the new library as the other ones of Sweet Home 3D. Llook how batik-svgpathparser-1.7.jar is handled for example, and keep in mind that in applets environment you'll have to update JNLP file as well as applet HTML code.
[Feb 4, 2015, 7:07:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Thank..... You Puybaret ......., It's working
[Feb 5, 2015, 3:16:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Hi Puybaret....
If you allow me , I would like to answer the questions which are publish in this forum and help the others..
Please let me know your decision....
[Feb 5, 2015, 9:54:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Hi Puybaret....
I'm bit stuck with one more thing. I was able to Add a button on tool bar as you said. I want to implement 3D view on/off function to that.
`Code in Applet Application
toolBar.addSeparator();
addActionToToolBar(homeView, HomeView.ActionType.TEST_BUTTON, toolBar);
Code in HomePane
createAction(ActionType.TEST_BUTTON, preferences, controller, "testMethod");
And Create a method in HomeControler
public void testMethod() {
System.out.println("Hi there.. I am the test method.. ");
is3DViewClicked = true;
View view = getHomeController3D().getView();
Once I press the button, the method is called. But I can't see the 3D view. Could you tell me how to view 3D panel ?
Thank You..
[Feb 8, 2015, 1:27:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you didn't create the 3D view as requested previously, don't be astonished that you can't manage it later!
[Feb 9, 2015, 3:28:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
The application which I developed using Sweet Home, is capable of detecting floor plan and drawing walls automatically. So If 3D view is enabled, system becomes slow.
Therefore I removed 3D view functionality and wanted to add a button to add 3D view functionality.
[Feb 10, 2015, 2:56:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you want to show/hide the 3D view, don't implement an other view factory to avoid its creation. Just make it invisible in the createHomeController method you overrode, and manage the divider of the JSplitPane grand parent of the 3D view when you show/hide the 3D view.
Feel free to help other users! All help is welcomed. smile
[Feb 10, 2015, 10:19:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
That's my issue. I couldn't find how to show/hide 3D pannel.
[Feb 10, 2015, 1:33:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
