Re: Need to deploy on Tomcat serer
Hi Pyubaret
I enhanced my application to detect the lines of the Floor plan which is in the grid. I used Boof CV(http://boofcv.org/index.php?title=Main_Page) libraries to do that. For the moment, it doesn't support all the floor plans. I'm improving the my line detecting algorithm.
But when I deployed the application on server(as a web application) with new feature, it says BoofCV libraries can't be found. I added BoofCV libraries under "otherLibraries" Tag in build.xml file. It compiles perfectly, but when it runs as a web application , it can't load added Boof CV libs. I would be thankful , if you tell me if there is another way to add libraries.
Manage the new library as the other ones of Sweet Home 3D. Llook how batik-svgpathparser-1.7.jar is handled for example, and keep in mind that in applets environment you'll have to update JNLP file as well as applet HTML code.
public void testMethod() { System.out.println("Hi there.. I am the test method.. "); is3DViewClicked = true; View view = getHomeController3D().getView();
Once I press the button, the method is called. But I can't see the 3D view. Could you tell me how to view 3D panel ?
If you didn't create the 3D view as requested previously, don't be astonished that you can't manage it later!
The application which I developed using Sweet Home, is capable of detecting floor plan and drawing walls automatically. So If 3D view is enabled, system becomes slow.
Therefore I removed 3D view functionality and wanted to add a button to add 3D view functionality.
