Total posts in this thread: 42
Posts: 42   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 21733 times and has 41 replies Next Thread
prabath
Re: Need to deploy on Tomcat serer
Thanks for your reply
[Jan 13, 2015, 5:02:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
I changed the source code to auto load the Floor Plan to the grid. It was successful when I ran the system as a Applet Application. But when I tried to Run as a web application, it doesn't work. Please help to sort out this issue.
[Jan 16, 2015, 3:58:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
How could I guess what you programmed???
Why not trying the defaultHome applet parameter?
[Jan 16, 2015, 7:50:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
charles0215
Thanks for these infos !!!
[Jan 23, 2015, 3:04:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Hi Puybaret
I went through the code you written. It's amazing work u have done. I want to do 1 more thing just to hide the 3D view. Can you pls tell me how to do that
[Jan 27, 2015, 11:47:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In a subclass of AppletApplication, you should override getViewFactory method to return a view factory (for example an instance of a subclass of SwingViewFactory) with a createView3D method that will return null.
Then, in a subclass of SweetHome3DApplet, override the method getApplicationClassName to return the name of the subclass of AppletApplication you programmed.
[Jan 27, 2015, 5:38:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Thank You Puybaret..
[Jan 28, 2015, 4:56:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
Hi Puybaret..
I want to add a button next to ZOOM OUT buttons. Please tell me how to add button. I found below link. Some method do not exist in that class.
http://www.sweethome3d.com/support/forum/view...F1D4E82105E7F6C79DF1A2202
Thank You
[Jan 29, 2015, 7:18:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Prabath, you request a lot of information but don't give any info to the community about the project you work on. It would be nice to present what you want to achieve, no?
[Jan 29, 2015, 8:40:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
prabath
:) I'm very sorry Puybaret. I'll explain.
I'm developing a online System for the Electricians to design Lights, Sockets and A/C systems for a selected Floor Plan. The application reads the PDF files and can detect the Floor Plans. Floor Plans are loaded with fixed scale.
3D view is not available. It is going to be handled by a separate button. So I struggled to add a new Button but failed.
[Jan 30, 2015, 12:36:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
