Re: Need to deploy on Tomcat serer
What do you mean by deploying sweethome3d jar on a server? You want to try to deploy the online version on a web server? If it's the case, the source code and the search engine of the forum will give you many hints.
Thanks for your Hint. I was able to set it up. When I set it up as a desktop application, application doen't allow me to save the designed floor plan. It says "Can't check if home exists".
There's no other documentation about this subject, but feel free to write one if you want.
You should set the floor plan you want in the applet parameter named defaultHome.
