Total posts in this thread: 6
Previous Thread This topic has been viewed 7971 times and has 5 replies Next Thread
gundeg
confused Is it possible to create glass wall?
I need to create transparent glass walls. is it possible? how? smile
[Sep 11, 2014, 4:30:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Is it possible to create glass wall?
Easiest - I find - is to use a transparent object. Import as window/door if you want it to run flush with the wall, or use it instead of a wall.
This model (posted in SourceForge 3D models 303) is what I use. Save the zip file and drag/drop into your model (check for door/window). Adjust size and change colour to your liking. If you need a frame for the glass wall, create a wall correct thickness and insert the transparent object into the wall.
[Sep 11, 2014, 8:33:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
OKH,
I like the colour of the glass, but unfortunately the glass isnt't very transparent at Q3 (not shown) and Q4 (shown).
image in Q2
image in Q4
[Sep 11, 2014, 11:05:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ah yes - I forgot to add that the glass wall is set to be reflective in rendering q3/q4 (using g sweethome3d_window_mirror in the .obj file - like a mirror - see the rest of the thread).
This example - glass_walls_reflection_and_not.sh3d - shows the same window with reflection (marked with a danger sign) and without reflection.
I posted the two other windows used in the example too in case the lab does not want reflective glass walls. As for the general transparency, you could change the d value in the .mtl file. But I guess it is the rendering you were after...
[Sep 11, 2014, 12:20:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
gundeg
thanks a lot
[Sep 12, 2014, 7:43:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
josephrohdes221
Really it is possible with the help of experts of this forum only, nicely explained and helped me a lot.
[Sep 30, 2014, 7:30:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
