Total posts in this thread: 2
Previous Thread This topic has been viewed 3657 times and has 1 reply Next Thread
aghast
Two-part wall (concrete/stud)
My ground floor features two exterior walls that are 8-inch concrete block at the bottom, about 3 feet high, and then 2x4 stud walls the rest of the way.
How do I represent this in SH3D?
[Sep 10, 2014, 8:34:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Two-part wall (concrete/stud)
If I understand you correctly, I would use multiple levels,
- The bottom level tree feet high (or with a negative elevation if there is a basement). Set walls height/thickness.
- Draw the stud walls on the next level(s).
Something like this: template_scandinavian.sh3d. This file assumes a basement, and different levels of terrain (just delete/ignore) - and walls are thicker than the ones you describe. But it think the principle is the same.
You may want to pay some attention to the accuracy of the measurements if you want - for instance - the wood panel set outside the stone/concrete foundation.
Good luck -
[Sep 11, 2014, 9:20:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
