Cameroon
Problem of executing the source code on eclipse
I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage
Exception in thread "main"java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte) at java.io.FileInputStream.open (Native Method ) at java.io.FileInputStream.<init>(Unknown Source) at java.io.FileInputStream.<init>(Unknown Source) at org.freehep.util.io.ASCII85InputStream.main (ASCII85InputStream.java:147 )
Re: Problem of executing the source code on eclipse
You mixed up "Program arguments" and "VM arguments" in eclipse run configuration.
INDIA
Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?. [* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ] Intreasted to learn and tweak. Thanks in advance.
INDIA
Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer. All kinds of tips are welcome.
Cameroon
Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks
INDIA
Question is simple When I get the SH3D sourcecode then how to build a jar application using Eclipse.? If you are successfull to create a sweethome3d.jar then share the methods you used. Thats it.
INDIA
Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scripting
