Total posts in this thread: 112
Posts: 112   Pages: 12   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Previous Thread This topic has been viewed 123081 times and has 111 replies Next Thread
Daniels118
Italy
Re: Pan tool in 3D and 2D view?
New version released!
The version 3.1 allows to toggle object selection in 3D view using SHIFT key + left mouse button, so multiple objects can be selected directly from the 3D view.
This enhancement will help a lot with the automatic wiring feature that will be added to the Wirings plugin very soon.
Download from SourceForge or using the Plugin manager.
[Apr 4, 2022, 1:13:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Version 3.2.1 (formerly 3.2b) adds the capability to modify openings and mannequin pose directly in the 3D view!
See it in action!
Notice: this is intended only for space analysis. The changes are temporary, they will be lost if you modify the furniture and when reopening the file.
[Edit 1 times, last edit by Daniels118 at May 6, 2022, 1:55:50 PM]
[May 5, 2022, 7:01:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Soulbrother
PLEASE help.
I cannot work properly with that, so I need to deinstall, but HOW TO??
Windows 10 - SH3D 6.6a
Already tried a new installation of sh3d, but it is still the same behaviour, I cannot navigate in the 3D window as before (before installation of that "tool")
[May 10, 2022, 9:29:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
I'm really sorry to hear that.
To unistall a plugin close SweetHome3D, go to "C:\Users\your_user_name\eTeks\Sweet Home 3D\plugins" and delete the plugin file.
If you wish to make it work maybe you could describe which behaviour you experience that prevent you from work.
[May 10, 2022, 3:15:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Soulbrother
Oh, thanks a lot for your fast answer!
The behaviour is button. but using your tool drives me crazy, because if I click the right mouse button and push the mouse, it fine and I can use it - same as before.
But everytime when I click the left mousebutton and push the mouse only 0,5mm on my table, the 3D view is completely turned over and I need to use one of my saved camera-positions to be able to come back to the same view-point...
For me it would be fine, if left and right buttons could be changed ( but only for this pan-tool, not generally in windows)
But I guess it´s on me, because no other has written such a "problem" ;-)
[May 10, 2022, 6:51:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
I'm not sure what causes the problem, I have even tried to swap left and right mouse buttons in Windows settings, but it stil works as expected for me.
Anyway I have modified the code to handle both buttons, please try the attached version and let me know.
Pan3dView-3.2.2.sh3p
[May 11, 2022, 7:59:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Version 3.3 released!
Changelog:
  • Added SPACE+left mouse button for panning as in plan view
  • Added Czech translation
  • Minor bug fix
Download from sourceforge or using the Plugin Manager.
Known bugs:
The "hide obstacles" feature is broken in Sweet Home 3D 7 beta. I'll try to fix it once SH3D 7 gets out the beta stage.
[Jul 8, 2022, 11:30:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Is there something I should have not changed in the program? Maybe it can be updated easily to avoid you to change your plug-in and manage different versions of Sweet Home 3D…
[Jul 9, 2022, 6:46:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
The problem is caused by the addition of the modelFlags parameter to the HomePieceOfFurniture3D.setVisible method, since it's a private method I did expect my code would have break soon or later. Handling both versions should be quite easy anyway.
[Jul 12, 2022, 8:55:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I could overload setVisible to keep the old signature too, but as it's a private method, the old version of the method will lead to warnings in Eclipse because it will be unused.
Thanks for accepting to fix it on your side smile
[Jul 12, 2022, 11:36:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
