Re: Sweet Home 3D 4.4
Then Sorry to say the problem is is still exist. You can clearly see it by set priority of javaw.exe to low in Task manager.
Too bad, anyway as long as it blinks, I think I won't go further. And there was an old memory management that needed to be fixed.
I am confused beta 19 is slightily slower in perfomance than beta 1, especially in Arial view ?
I don't see what change could have produce such a performance slowdown, because the main change in the 3D part was about texture rotation. Did you try also with version 4.3?
You are right , but reducing the Refraction Index less than '1' can make easly setup metal like gold.(0.4-0.6)
Refraction Index is used only for transparent material in SunFlow. As far as I know, gold isn't transparent in solid and liquid state. In a gaseous state, I have no idea, but I don't think it's interesting for Sweet Home 3D, do you?
The Beta 20 checks if there's enough disk space to save a home file. As file systems can very different, I would be pleased to know if it works for you all. Please test on full USB keys, remote user spaces…
INDIA
Yes, you done it successfully to check the disk space. I wish the font size used at "Missing 6.5 MB to save home" may be bigger is better. For me it is too small to read in 1280x960 resolution monitor . Also change the window title to 'Not enough Disk Space'( Its not a 'Error', Its a warning, I think).
sree.arun.kr, thanks for your tests. About the message presentation, I'll improve it in a future version, because I want to suggest also to the user to save his home with Save and compress option if he chose a simple save. But adding this message would require a new translation round, that I won't start for version 4.4 again.
INDIA
Before releasing v4.4 I wish it is the time to add an icon file of size 256x256 for the new generation users(W7,W8) with a good quality.
Are you sure that this icon file wouldn't prevent the program from working under Windows XP?
Ok, I just added a 256x256 icon to SweetHome3D.ico, and checked it worked under Windows XP and 8.
When testing sh3d 4.4 beta, I noticed this: 3d pane: (virtual visit mode) when furniture is moved (in the upper plan) the 3d view gets greyed out. However, when you move the virtual visitor, the pane goes back to normal. This also happens when you move the size of the window pane.
