Total posts in this thread: 96
Posts: 96   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 321123 times and has 95 replies Next Thread
Re: Sweet Home 3D 4.4
Thanks for your feedback smile
First bug: plug-in Rotate doesn't work properly anymore
I don't think this plug-in ever worked with Java Web Start for security reasons.
making a photo in Q4 is extremely slow.
I didn't measure performances difference yet, but I'll check...
[Apr 4, 2014, 4:19:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Again congratulations. It is so nice to see new sw versions that actually improves stuff. Also, no crashes, nothing unexpected so far.
- an improved texture chooser ...
Indeed, great improvement!
- .. SunFlow to avoid black dots .. support transparent textures...
Still get (the same) black dots using both versions with photo from same setting - will look some more. I noticed no performance differences at best setting, though.
- new Edit > Select all at all levels ...
Selects like expected. Move workes nicely, rotate (advanced) plugin made a bit of a mess (which could not be undone) - but it did work, sort of...
- new dropOnTopElevation property to place .. at a preferred elevation..
If I understand you correctly a dropOnTopElevation#1=82 means that other furniture you later import (on top) will end up with an elevation of 82? Regardless of whether the item is higher or lower? If so, this could be useful.
- new Furniture > Reset elevation ..
Reset to the elevation to previous value? Not to the original elevation#nn= value?
- KMZ file format support ...
I am sure many users will appreciate easier access to the 3D warehouse.
.. beta version of the furniture libraries...
I think maybe you are at a point where selecting which items to include (in default library) is getting to be difficult. But then, as a puritan I would prefer the basic selection to be simple, compact and generic. Fully realising that many (most) would probably disagree.
Good luck - and thanks!
[Apr 4, 2014, 4:58:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, you're right. I made some other tests. There was no performance loss but there were as much black dots as previously. sad
Since its original developer haven't touched this library for years, I think it's a dead end now. I spent so much time trying to manage texture transparency and feel it's still not perfect. I guess better renderings can be achieved only if I now integrate an other library.
Yes it's exactly this behavior. It should help to place accessories much faster on some tables, shelves, cabinets, but also under trees, plants… If this property is negative, the height of the surrounding object will even been ignored.
Reset to the value that would be used if you set elevation to 0 then drop the piece of furniture again on a surrounding object. So not to the original elevation#nn value.
Users will appreciate it mostly once Trimble will have added back a filter for KMZ files in 3D Warehouse search engine, like I requested some time ago (feel free to post yourself a message to show you want this filter too).
We will see in the future how to handle this at best, and why not proposing libraries organized by themes. At the moment, my goal is to reach 1000 models for Sweet Home 3D available under a free license, and we're very close. Expect a nice surprise with version 4.4. wink
[Apr 4, 2014, 6:01:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks - anyway, very happy. Not too concerned with the black dots either. 1000 models, easy, which ones, that is the hard one.
Got one odd error message that I have not seen (noticed) before:
Exception in thread "AWT-EventQueue-2" java.lang.IllegalArgumentException: Value too long: Stairs 90 closed legal high,Roof,toalettslange,tallerkenhylle,……..
at java.util.prefs.AbstractPreferences.put(Unknown Source)
at com.eteks.sweethome3d.io.FileUserPreferences.write(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$UserPreferencesChangeListener$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
[Note from moderator: Reduced Value to avoid tooooo long line]
[Edit 1 times, last edit by Puybaret at Apr 4, 2014, 9:58:28 PM]
[Apr 4, 2014, 7:32:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the bug report smile
That may explain why the bug #415 doesn't happen all the time. It must depends on how many new words you entered during a session of Sweet Home 3D. If there are too many words (more exactly if the list is longer than 8092 characters), Java will refuse to write it in preferences along with other values like the recent files list, the recent colors…
It will be fixed in the next version.
[Apr 4, 2014, 10:13:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Aha, thanks, the mysterious bug #415 has been a pain. Strange list, though. ".. a session..." you say? Certainly not from a recent session. Even one of the very first models I imported was there, never used since.
I looked at \eTeks\Sweet Home 3D\preferences.xml - it is the autoCompletionStrings, right? <entry key="autoCompletionStrings#3"> (3 of 4): 557 entries, 8190 characters (including commas).
As I need to do spring cleaning in my settings (i.e. \eTeks\Sweet Home 3D\ , on my Win8.1 - too many test textures etc - will be better with new texture editor...). Can I just delete the content of the entries in autoCompletionStrings# ? I need recent-files more than autocomplete...
Or even better, could I just clean out the whole top settings directory: settings, textures and furniture (not the sub-dirs with furniture- and texturelibraries) to wash out all test-stuff ?smile
[Apr 5, 2014, 11:36:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Actually, that was a stupid question. Sorry. Just did, and it works. Recent files are back. Me happy smile.
By the way, the new version splash warning confuses me a bit.
The home "C:\xxx\xxx\xxxx.sh3d" was created with a more recent version of Sweet Home 3D.
The information added to home in that version won't appear with the version of Sweet Home 3D you use now.
As far as I can tell all of the information added in 4.4 BETA is also available when using 4.3.
[Apr 5, 2014, 12:12:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Before changing anything in eTeks\Sweet Home 3D private folder, I would create a backup of it, so if something goes wrong, you can get back your previous settings.
No, a rotated texture won't appear as rotated in version 4.3 and if you save a sh3d file with Sweet Home 3D 4.3 in which you used a rotated texture, it won't appear as rotated anymore when you reopen it in version 4.4. Same thing for dropOnTopElevation value, and future information that might be added in coming beta versions.
[Apr 5, 2014, 12:31:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pmralbuquerque
Portugal
Hi Emmanuel,
there are some menu commands needing translation, but I can't find them in the language file available on the site. Is it my error?
Regards,
Pedro.
[Apr 6, 2014, 10:10:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pedro, the new features are only translated in English and French at this moment.
Once all the features I want to add will be in the beta version, I'll write to you and other translators to translate all of them in one go. Easier for me and for you wink
[Apr 6, 2014, 1:34:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
