Total posts in this thread: 2
Previous Thread This topic has been viewed 2531 times and has 1 reply Next Thread
Reddog
United Kingdom
Unused items
new to this... a couple of questions..
how do i delete unused items?... i have loads of suff clogging up my 'home furniture' list that i am not using.. i have them set to invisible at the moment, but would like to remove them entirely.
and i want to create an opening fora fireplace that is not square is there a customisable rectangle somewhere?
thanks,
Keith
[Mar 26, 2014, 12:00:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Unused items
In home (lower left pane): Select, right-click > Delete or just DEL (but make sure plan is unlocked if items are part of base plan). In furniture list (upper left pane), imported furniture can be deleted, furniture catalogues must be removed - see this thread.
An invisible object imported as a door window, will cut a wall to the correct shape. It sounds to me that you could place your fireplace object half way into the wall (turn of magnetism with ALT) and then insert an opening (eg Service Hatch) around the opening in the fireplace - or am I missing the point?
PS - you really had me wondering for a sec what a "fora fireplace" was, had not heard of those before smile
[Mar 26, 2014, 3:23:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
