Total posts in this thread: 6
Previous Thread This topic has been viewed 5200 times and has 5 replies Next Thread
arcgee
angry Can't open Sweet Home 4.3 on my Mac OS 10.9.2
I installed Sweet Home 4.2. It installed but would not open. I upgraded Java as a thread suggested. Then I installed Sweet Home 4.3. It won't open. Help!! crying
[Mar 3, 2014, 10:23:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can't open Sweet Home 4.3 on my Mac OS 10.9.2
Please give more details.
What do you mean by "it won't open"? Don't you see the splash screen of Sweet Home 3D when you launch the program? Can't you open an existing document?
[Mar 4, 2014, 3:26:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
peterwood
Same here.
Sweet Home 3D v. 4.3 on Mac OS X 10.9.
If you double click the icon it just does nothing.
In a terminal If I run:
$ /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
[JavaAppLauncher] Requested [1.5*], launching in [1.7] instead.
JavaVM: Failed to load JVM: /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk/Contents/Home/bundle/Libraries/libserver.dylib
JavaVM FATAL: Failed to load the jvm library.
[JavaAppLauncher Error] JNI_CreateJavaVM() failed, error: -1
I have a file created with version 4.2 on Mac OS 10.8 called Home-2ndFloor.sh3d
In a terminal if I run:
$ open Home-2ndFloor.sh3d
LSOpenURLsWithRole() failed with error -10810 for the file Home-2ndFloor.sh3d
I installed the version that is bundled with Java.
Any idea what may be wrong? How to fix it?
Thanks,
-- Peter
[Mar 14, 2014, 12:52:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Install Apple Java. If you run the program by double clicking on Sweet Home 3D icon instead of using Terminal, it should propose to install it automatically.
[Mar 14, 2014, 9:57:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
peterwood
I have java:
$ java -version
java version "1.7.0_51"
Java(TM) SE Runtime Environment (build 1.7.0_51-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.51-b03, mixed mode)
Double clicking on the icon does nothing.
I downloaded SweetHome3D-4.3.jar and this works:
java -Xmx2048m -jar SweetHome3D-4.3.jar
So, I have a working solution. I just wished the icon will work too.
Thanks for the great product.
[Mar 14, 2014, 8:05:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you install Apple Java 6?
[Mar 15, 2014, 11:51:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
