Re: exterior-door-03.zip
If you import an object, checking the Door/Window checkbox, it will adjust to the walls and cut the correct opening. It will also behave like a door in the 2D view, but if you want the 2D view to display the door opening etc, you need to use a door which also supplies these properties (like the ones in the pre-installed collection). The file you mention, is an .obj file which does not support such extra features (wall thickness, door opening/angle, etc).
Exists there a 3D model designer which as easy to use as SH3D?
Short answer, no :-( - see this thread and lots of other threads.
AoI, Blender, Sketchup, Wings 3D - and then obviously commercial ones - matter of preference. All 3D modelling software will require some patience in the learning process.
Furniture Library Editor: Just a "converter"..
The Furniture Library Editor is a furniture library editor it deals with libraries of models: converts, scales, lets you add cut-outs etc. but not designer.
Note that for the door swing you wish to display in the 2D win, you need only an editor - PluginFurnitureCatalog.properties is a (zipped) plain vanilla ascii file specifying properties of library elements.
