United States
Modify walls is greyed out
The 'modify walls' menu choice is greyed out when I select the walls of my plan. When I click on a wall, all of the walls are highlighted in purple and arrows appear at each intersection. The plan is not locked.
I am using a MacBook running OS 10.9.1, Sweet Home 3D version 4.3 and Java version 1.6.0_65. I have read the user manual and posts on this topic from 2010 and 2012.
I apologize in advance since I'm probably missing something obvious.
Re: Modify walls is greyed out
I fear you encountered the following bug: sometimes, when you start to create levels in a home that is not empty, furniture and walls previously added are not assigned to the first level. As I couldn't reproduce this bug, I couldn't fix it but fortunately it happens very rarely. Please send me your file, and I'll fix it for you.
