Web Viewer keyboard not working
Hi
I have tried to place my project online for my friends to watch. It works using mouse, but the keyboard is not functional at all. Is there a mouse gesture to go to aerial view or can I force the viewer to start in aerial view.
Any others having this problem? Could it be a problem with my browser java (using IceTea on OpenSUSE).
Re: Web Viewer keyboard not working
Did you click in the 3D view first? Doesn't the space bar let you switch between Aerial view and Virtual visit modes?
The viewer view is the same as the view when you saved the file. So yes, just save your file in aerial view (Ctrl-D) and upload again.
Thanks. That should be a useable workaround.
PS Det var da et nett lite hus - er det reelt eller en drøm?
It is a real project. My wife blogs about it on our new blog huset i Busene. And I would like to say that Sh3d have been a fantastic help, when planning how to get the most out a small house like that.
Yes I did click in the app and I am able to pan the view using the mouse in the app view. Likewise I can move around using mouse on the small arrows i the upper left corner. But still after this, the keyboard does nothing, not the spacebar and neither does the arrow keys.
Further. I asked my colleague to try it at work today. He is using Windows 7 and newest Oracle Java. He does not even get a view. The app seems to startup well. After accepting the warning popups the cirle spins a little around a cup - and he just gets a blank app vindow.
What a fantastic project and location. I have sailed past Møns Klint - should have explored the area further. I hope you will develop the model with roof and everything as the project progresses.
Your house in SH3D viewer works like charm from here, Win 8, Opera plugin and Java 1.7.0_45-b18. However, download/reading of the 2MB .sh3d file is mysteriously slow (could be the transfer).
It sure is a wonderful spot in Denmark, I highly recommend trekking in the area.
Wont make any promises As you see there is quite a lot of real work to do, before the house gets anywhere near the drawing.
Thanks. I have tried the viewer on a handfull machines with different opsys/browser/java - and gets mixed results. Mostly (3 out of 4) it seems to work though (with og without keyboard).
The house works fine under Ubuntu 12.04 using a mouse. Keyboard isn't functional.
It's a very nice, functional and interesting layout you chose. However I would make a few minor changes.
1 - Mirror the central part, so the fire place faces the sitting area, not the dining area. 2 - In my country (Netherlands) you wouldn't be allowed to have a toilet with direct access from a living space. Neither would I like to smell the smells when you leave the toilet. The central space is big enough to find a different solution. 3 - Give the little desk a different place, e.g. under the window next to the back door. You get better light and take advantage of the view.
Good luck with theory and real work. Just wanted to say that it is very nice to see people with interesting projects using the viewer for presentation.
