Previous Thread This topic has been viewed 3590 times and has 2 replies Next Thread
duckjockey
Can a 'sloping' box be made?
Is it possible to make a box with a sloping dimension? For example, I'd like to make a 8"X12"X120" long box to represent a beam that is at 96" elevation on one end, and 120" at the other. I'm currently using a old version of SweetHome. Perhaps the latest can do this? Thank you.
[Jan 4, 2014, 7:13:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can a 'sloping' box be made?
Draw a wall with the correct 8"x12"x120" dimensions in SH3D, where one end is 24" (120" - 96") further down in the 2d view than the other. Export to .obj format, and import the same file as furniture. When importing, rotate your object from horizontal to vertical with the green arrows.
[Jan 4, 2014, 8:55:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Neither the old, nor any new version can do that in-program (or real-time).
However, there is a simple way to accomplish this.
Export the beam of choice, then re-import it.
In the first step of importation, you can use the arrow buttons to rotate the object along X, Y and Z axis.
Good luck.
[Jan 4, 2014, 8:57:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
