Total posts in this thread: 4
Previous Thread This topic has been viewed 3144 times and has 3 replies Next Thread
carlos_spork
Argentina
Newbie: How do I draw a room to match a wall with an arc?
Hello,
I can't find a way to draw the room (floor) inside a room that has a wall with a 90-degree arc. Can someone help me with this?
Thank you so much!
[Oct 25, 2013, 11:50:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Newbie: How do I draw a room to match a wall with an arc?
Carlos,
To draw a room, choose the Room button, then double-click inside your room.
If that doesn´t work, the walls of your room aren´t closed. Make sure that all walls are connected, or edit the X,Y coordinates so that the end of one wall has the same coordinates as the start of the next wall.
[Oct 25, 2013, 11:54:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
carlos_spork
Argentina
Thank you so much, Hans! I didn't know about the double-click feature to create a room. In my case, the walls weren't closed anyway. I also noticed that, in the end, it's just a matter of "connecting the dots", so I just added additional dots to make it look a bit better when zooming-in in the 3D-view.
Again, thank you!
[Oct 26, 2013, 2:39:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
carlos_spork
Argentina
By the way, Hans, this is an example of what I was trying to achieve: Gravel access-path
[Oct 26, 2013, 3:43:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
