Re: models
1 - Use Furniture -> Modify -> Materials -> Modify to change colours. 2 - This message explains how you can use images.
[Edit 1 times,
last edit by hansmex at Oct 24, 2013, 11:14:37 AM]
Spain
Re: models
With this I have a other question how can I add floors to my already finished home I forgot to add them in the beginning... :-(
In case you mean how to add a floor to the rooms so you can use a texture on them, you only need to select the "create rooms" tool and double click inside each room.
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
my house have three levels (bell etage) 0,1 and 2 level 0 is garage, level 1 is the living room and on level 2 are the bedrooms/bathroom so when you are on level 0 you see the stairs that goining to level 1 on the image the stairs is turning below and I would like to change it like on the next picture,turning on top;
