# A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6ed05861, pid=5644, tid=3680 # # JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18) # Java VM: Java HotSpot(TM) Client VM (24.45-b08 mixed mode, sharing windows-x86 ) # Problematic frame: # C [aticfx32.dll+0x25861] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # If you would like to submit a bug report, please visit: #
http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x009eb800): JavaThread "main" [_thread_in_native, id=3680, stack(0x00a00000,0x00a50000)] siginfo: ExceptionCode=0xc0000005, reading address 0x0000013c Registers: EAX=0x00000008, EBX=0x00a4ec60, ECX=0x0000000a, EDX=0x00000000 ESP=0x00a4e270, EBP=0x00a4e27c, ESI=0x06a22898, EDI=0x06a207d0 EIP=0x6ed05861, EFLAGS=0x00010202 Top of Stack: (sp=0x00a4e270) 0x00a4e270: 00a4ec60 06a207d0 00000000 00a4ec10 0x00a4e280: 6ed03f2c 400000c0 00a4ec60 0041dcd4 0x00a4e290: 005ba7c0 400000c0 00000000 00a4e2a8 0x00a4e2a0: 00000960 400000c0 00000001 088d0000 0x00a4e2b0: 0000000a 00000000 00000008 00000007 0x00a4e2c0: 0000027c 0000073b 00000001 00000001 0x00a4e2d0: 00008bc3 00000001 00001f9d 000007fc 0x00a4e2e0: 00000001 e2f32107 000001ba 00f7ff3f Instructions: (pc=0x6ed05861) 0x6ed05841: 6e 68 88 00 00 00 6a 08 52 8b f8 ff 15 b0 a0 d2 0x6ed05851: 6e 8b f0 85 f6 74 1b 8b 47 20 8b 4f 14 83 c0 08 0x6ed05861: 8b 80 34 01 00 00 50 8b c7 e8 21 ff ff ff 8b f0 0x6ed05871: eb 02 33 f6 8b fe e8 54 24 01 00 85 c0 7c 1d 53 Register to memory mapping: EAX=0x00000008 is an unknown value EBX=0x00a4ec60 is pointing into the stack for thread: 0x009eb800 ECX=0x0000000a is an unknown value EDX=0x00000000 is an unknown value ESP=0x00a4e270 is pointing into the stack for thread: 0x009eb800 EBP=0x00a4e27c is pointing into the stack for thread: 0x009eb800 ESI=0x06a22898 is an unknown value EDI=0x06a207d0 is an unknown value Stack: [0x00a00000,0x00a50000], sp=0x00a4e270, free space=312k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [aticfx32.dll+0x25861] C [aticfx32.dll+0x23f2c] C [atigktxx.dll+0x1daf] Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j javax.media.j3d.NativePipeline.getSupportedOglVendorNative()Ljava/lang/String;+0 j javax.media.j3d.NativePipeline.getSupportedOglVendor()Ljava/lang/String;+45 j javax.media.j3d.Pipeline.useNativeOgl(ZZ)Z+0 j javax.media.j3d.MasterControl.loadLibraries()V+425 j javax.media.j3d.VirtualUniverse.<clinit>()V+209 v ~StubRoutines::call_stub j javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration([Ljava/awt/GraphicsConfiguration;)Ljava/awt/GraphicsConfiguration;+57 j java.awt.GraphicsDevice.getBestConfiguration(Ljava/awt/GraphicsConfigTemplate;)Ljava/awt/GraphicsConfiguration;+7 j com.eteks.sweethome3d.j3d.Component3DManager.<init>()V+25 j com.eteks.sweethome3d.j3d.Component3DManager.getInstance()Lcom/eteks/sweethome3d/j3d/Component3DManager;+10 j com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver()V+8 j com.eteks.sweethome3d.SweetHome3D.init([Ljava/lang/String;)V+104 j com.eteks.sweethome3d.SweetHome3D.main([Ljava/lang/String;)V+8 v ~StubRoutines::call_stub j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0 j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87 j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6 j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+57 j com.eteks.sweethome3d.SweetHome3DBootstrap.main([Ljava/lang/String;)V+362 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) 0x0486f800 JavaThread "pool-2-thread-1" [_thread_in_native, id=3836, stack(0x05550000,0x055a0000)] 0x0486d400 JavaThread "pool-1-thread-1" [_thread_blocked, id=4196, stack(0x051d0000,0x05220000)] 0x04857800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5164, stack(0x052c0000,0x05310000)] 0x04859c00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1060, stack(0x05370000,0x053c0000)] 0x04859400 JavaThread "AWT-Shutdown" [_thread_blocked, id=1892, stack(0x05260000,0x052b0000)] 0x04853400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3812, stack(0x05150000,0x051a0000)] 0x00988400 JavaThread "Service Thread" daemon [_thread_blocked, id=3544, stack(0x04690000,0x046e0000)] 0x00980c00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=2512, stack(0x04640000,0x04690000)] 0x0097f800 JavaThread "Attach Listener" daemon [_thread_blocked, id=3340, stack(0x04570000,0x045c0000)] 0x0097c800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4012, stack(0x04450000,0x044a0000)] 0x00915000 JavaThread "Finalizer" daemon [_thread_blocked, id=5144, stack(0x043f0000,0x04440000)] 0x00910000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2376, stack(0x04240000,0x04290000)] =>0x009eb800 JavaThread "main" [_thread_in_native, id=3680, stack(0x00a00000,0x00a50000)] Other Threads: 0x0090e400 VMThread [stack: 0x00c00000,0x00c50000] [id=2976] 0x00999400 WatcherThread [stack: 0x04720000,0x04770000] [id=3276] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 4928K, used 3335K [0x247d0000, 0x24d20000, 0x29d20000) eden space 4416K, 63% used [0x247d0000, 0x24a91ca0, 0x24c20000) from space 512K, 100% used [0x24ca0000, 0x24d20000, 0x24d20000) to space 512K, 0% used [0x24c20000, 0x24c20000, 0x24ca0000) tenured generation total 10944K, used 917K [0x29d20000, 0x2a7d0000, 0x347d0000) the space 10944K, 8% used [0x29d20000, 0x29e05610, 0x29e05800, 0x2a7d0000) compacting perm gen total 12288K, used 1840K [0x347d0000, 0x353d0000, 0x387d0000) the space 12288K, 14% used [0x347d0000, 0x3499c318, 0x3499c400, 0x353d0000) ro space 10240K, 41% used [0x387d0000, 0x38c01a78, 0x38c01c00, 0x391d0000) rw space 12288K, 52% used [0x391d0000, 0x398162c0, 0x39816400, 0x39dd0000) Card table byte_map: [0x00b50000,0x00c00000] byte_map_base: 0x00a2c180 Polling page: 0x00160000 Code Cache [0x02220000, 0x022e8000, 0x04220000) total_blobs=381 nmethods=87 adapters=231 free_code_cache=31990Kb largest_free_block=32757824 Compilation events (10 events): Event: 1.884 Thread 0x00980c00 83 java.util.Arrays::copyOf (19 bytes) Event: 1.884 Thread 0x00980c00 nmethod 83 0x022d9188 code [0x022d9290, 0x022d93fc] Event: 1.885 Thread 0x00980c00 84 java.lang.AbstractStringBuilder::expandCapacity (50 bytes) Event: 1.886 Thread 0x00980c00 nmethod 84 0x022d94c8 code [0x022d95e0, 0x022d9818] Event: 1.886 Thread 0x00980c00 85 java.lang.AbstractStringBuilder::<init> (12 bytes) Event: 1.886 Thread 0x00980c00 nmethod 85 0x022d9948 code [0x022d9a40, 0x022d9b50] Event: 1.886 Thread 0x00980c00 86 java.lang.System::getSecurityManager (4 bytes) Event: 1.886 Thread 0x00980c00 nmethod 86 0x022d9bc8 code [0x022d9cc0, 0x022d9d30] Event: 1.888 Thread 0x00980c00 87 java.lang.ref.Reference::get (5 bytes) Event: 1.888 Thread 0x00980c00 nmethod 87 0x022d9d88 code [0x022d9e80, 0x022d9f00] GC Heap History (2 events): Event: 1.822 GC heap before {Heap before GC invocations=0 (full 0): def new generation total 4928K, used 4416K [0x247d0000, 0x24d20000, 0x29d20000) eden space 4416K, 100% used [0x247d0000, 0x24c20000, 0x24c20000) from space 512K, 0% used [0x24c20000, 0x24c20000, 0x24ca0000) to space 512K, 0% used [0x24ca0000, 0x24ca0000, 0x24d20000) tenured generation total 10944K, used 0K [0x29d20000, 0x2a7d0000, 0x347d0000) the space 10944K, 0% used [0x29d20000, 0x29d20000, 0x29d20200, 0x2a7d0000) compacting perm gen total 12288K, used 1321K [0x347d0000, 0x353d0000, 0x387d0000) the space 12288K, 10% used [0x347d0000, 0x3491a480, 0x3491a600, 0x353d0000) ro space 10240K, 41% used [0x387d0000, 0x38c01a78, 0x38c01c00, 0x391d0000) rw space 12288K, 52% used [0x391d0000, 0x398162c0, 0x39816400, 0x39dd0000) Event: 1.829 GC heap after Heap after GC invocations=1 (full 0): def new generation total 4928K, used 512K [0x247d0000, 0x24d20000, 0x29d20000) eden space 4416K, 0% used [0x247d0000, 0x247d0000, 0x24c20000) from space 512K, 100% used [0x24ca0000, 0x24d20000, 0x24d20000) to space 512K, 0% used [0x24c20000, 0x24c20000, 0x24ca0000) tenured generation total 10944K, used 917K [0x29d20000, 0x2a7d0000, 0x347d0000) the space 10944K, 8% used [0x29d20000, 0x29e05610, 0x29e05800, 0x2a7d0000) compacting perm gen total 12288K, used 1321K [0x347d0000, 0x353d0000, 0x387d0000) the space 12288K, 10% used [0x347d0000, 0x3491a480, 0x3491a600, 0x353d0000) ro space 10240K, 41% used [0x387d0000, 0x38c01a78, 0x38c01c00, 0x391d0000) rw space 12288K, 52% used [0x391d0000, 0x398162c0, 0x39816400, 0x39dd0000) } Deoptimization events (0 events): No events Internal exceptions (10 events): Event: 0.659 Thread 0x009eb800 Threw 0x24a8dce8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 0.660 Thread 0x009eb800 Threw 0x24a93ac0 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 0.660 Thread 0x009eb800 Threw 0x24a93eb0 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 0.661 Thread 0x009eb800 Threw 0x24aa4610 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 0.661 Thread 0x009eb800 Threw 0x24aa4a38 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 1.666 Thread 0x009eb800 Threw 0x24ab50a8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jni.cpp:743 Event: 1.687 Thread 0x009eb800 Threw 0x24ade2a8 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jni.cpp:717 Event: 1.749 Thread 0x009eb800 Threw 0x24b81c50 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jni.cpp:717 Event: 1.882 Thread 0x009eb800 Threw 0x249d9e98 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Event: 1.882 Thread 0x009eb800 Threw 0x249da500 at C:\re\jdk7u45\229\hotspot\src\share\vm\prims\jvm.cpp:1244 Events (10 events): Event: 1.882 loading class 0x048db7e0 Event: 1.882 loading class 0x048db7e0 done Event: 1.882 loading class 0x39e2e240 Event: 1.882 loading class 0x39e2e240 done Event: 1.882 loading class 0x0485d8f8 Event: 1.882 loading class 0x0485d8f8 done Event: 1.883 loading class 0x39e2ff10 Event: 1.883 loading class 0x39e2ff10 done Event: 1.892 loading class 0x39e32068 Event: 1.892 loading class 0x39e32068 done Dynamic libraries: 0x00df0000 - 0x00e1f000 C:\Program Files (x86)\Java\jre7\bin\javaw.exe 0x77230000 - 0x773b0000 C:\Windows\SysWOW64\ntdll.dll 0x76870000 - 0x76980000 C:\Windows\syswow64\kernel32.dll 0x767b0000 - 0x767f7000 C:\Windows\syswow64\KERNELBASE.dll 0x766c0000 - 0x76760000 C:\Windows\syswow64\ADVAPI32.dll 0x75480000 - 0x7552c000 C:\Windows\syswow64\msvcrt.dll 0x76d80000 - 0x76d99000 C:\Windows\SysWOW64\sechost.dll 0x75620000 - 0x75710000 C:\Windows\syswow64\RPCRT4.dll 0x74c50000 - 0x74cb0000 C:\Windows\syswow64\SspiCli.dll 0x74c40000 - 0x74c4c000 C:\Windows\syswow64\CRYPTBASE.dll 0x75770000 - 0x75870000 C:\Windows\syswow64\USER32.dll 0x753d0000 - 0x75460000 C:\Windows\syswow64\GDI32.dll 0x76990000 - 0x7699a000 C:\Windows\syswow64\LPK.dll 0x74cb0000 - 0x74d4d000 C:\Windows\syswow64\USP10.dll 0x74660000 - 0x747fe000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll 0x76810000 - 0x76867000 C:\Windows\syswow64\SHLWAPI.dll 0x75710000 - 0x75770000 C:\Windows\system32\IMM32.DLL 0x74dd0000 - 0x74e9c000 C:\Windows\syswow64\MSCTF.dll 0x6fb30000 - 0x6fbef000 C:\Program Files (x86)\Java\jre7\bin\msvcr100.dll 0x6f5a0000 - 0x6f920000 C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll 0x735a0000 - 0x735a7000 C:\Windows\system32\WSOCK32.dll 0x755e0000 - 0x75615000 C:\Windows\syswow64\WS2_32.dll 0x76800000 - 0x76806000 C:\Windows\syswow64\NSI.dll 0x743d0000 - 0x74402000 C:\Windows\system32\WINMM.dll 0x75460000 - 0x75465000 C:\Windows\syswow64\PSAPI.DLL 0x70730000 - 0x7073c000 C:\Program Files (x86)\Java\jre7\bin\verify.dll 0x6fc10000 - 0x6fc30000 C:\Program Files (x86)\Java\jre7\bin\java.dll 0x6fbf0000 - 0x6fc03000 C:\Program Files (x86)\Java\jre7\bin\zip.dll 0x6faa0000 - 0x6fab4000 C:\Program Files (x86)\Java\jre7\bin\net.dll 0x73eb0000 - 0x73eec000 C:\Windows\system32\mswsock.dll 0x73ea0000 - 0x73ea6000 C:\Windows\System32\wship6.dll 0x6fa90000 - 0x6fa9f000 C:\Program Files (x86)\Java\jre7\bin\nio.dll 0x74150000 - 0x74166000 C:\Windows\system32\CRYPTSP.dll 0x74110000 - 0x7414b000 C:\Windows\system32\rsaenh.dll 0x73fa0000 - 0x73fb7000 C:\Windows\system32\USERENV.dll 0x73f90000 - 0x73f9b000 C:\Windows\system32\profapi.dll 0x6efe0000 - 0x6eff0000 C:\Windows\system32\NLAapi.dll 0x6efd0000 - 0x6efe0000 C:\Windows\system32\napinsp.dll 0x6ef80000 - 0x6ef92000 C:\Windows\system32\pnrpnsp.dll 0x742b0000 - 0x742f4000 C:\Windows\system32\DNSAPI.dll 0x6efc0000 - 0x6efc8000 C:\Windows\System32\winrnr.dll 0x6ef70000 - 0x6ef7d000 C:\Windows\system32\wshbth.dll 0x73e90000 - 0x73e95000 C:\Windows\System32\wshtcpip.dll 0x74310000 - 0x7432c000 C:\Windows\system32\IPHLPAPI.DLL 0x74300000 - 0x74307000 C:\Windows\system32\WINNSI.DLL 0x6ef30000 - 0x6ef36000 C:\Windows\system32\rasadhlp.dll 0x6eef0000 - 0x6ef28000 C:\Windows\System32\fwpuclnt.dll 0x6e940000 - 0x6ea83000 C:\Program Files (x86)\Java\jre7\bin\awt.dll 0x769a0000 - 0x76a2f000 C:\Windows\syswow64\OLEAUT32.dll 0x75240000 - 0x7539c000 C:\Windows\syswow64\ole32.dll 0x6f9d0000 - 0x6f9f5000 C:\Program Files (x86)\Java\jre7\bin\jpeg.dll 0x74330000 - 0x74343000 C:\Windows\system32\DWMAPI.DLL 0x74350000 - 0x743d0000 C:\Windows\system32\uxtheme.dll 0x6fc60000 - 0x6fc98000 C:\Program Files (x86)\Java\jre7\bin\fontmanager.dll 0x10000000 - 0x1000e000 C:\Users\Caro\AppData\Local\Temp\extension2166736302759266880.dll 0x6e870000 - 0x6e938000 C:\Windows\system32\OPENGL32.dll 0x6f9a0000 - 0x6f9c2000 C:\Windows\system32\GLU32.dll 0x6ce40000 - 0x6cf27000 C:\Windows\system32\DDRAW.dll 0x6f990000 - 0x6f996000 C:\Windows\system32\DCIMAN32.dll 0x76b60000 - 0x76cfd000 C:\Windows\syswow64\SETUPAPI.dll 0x74ff0000 - 0x75017000 C:\Windows\syswow64\CFGMGR32.dll 0x75880000 - 0x75892000 C:\Windows\syswow64\DEVOBJ.dll 0x05ba0000 - 0x06645000 C:\Windows\system32\ig4icd32.dll 0x6f970000 - 0x6f978000 C:\Windows\system32\atigktxx.dll 0x74290000 - 0x74299000 C:\Windows\system32\VERSION.dll 0x6ece0000 - 0x6ed68000 C:\Windows\system32\aticfx32.dll 0x6e760000 - 0x6e84b000 C:\Windows\system32\dbghelp.dll VM Arguments: java_command: C:\Users\Caro\Downloads\SweetHome3D-3.7.jar Launcher Type: SUN_STANDARD Environment Variables: PATH=C:Windowssystem32;C:Windows;C:Windowssystem32wbem;C:WindowsSystem32WindowsPowerShellv1.0;C
:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn;C:\Users\Caro\AppData\Local\Smartbar\Application\ USERNAME=Caro OS=Windows_NT PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 5, GenuineIntel --------------- S Y S T E M --------------- OS: Windows 7 , 64 bit Build 7601 Service Pack 1 CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 37 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, popcnt, tsc, tscinvbit Memory: 4k page, physical 3984048k(2045256k free), swap 7966232k(5634220k free) vm_info: Java HotSpot(TM) Client VM (24.45-b08) for windows-x86 JRE (1.7.0_45-b18), built on Oct 8 2013 06:02:43 by "java_re" with unknown MS VC++:1600 time: Sun Oct 20 13:46:22 2013 elapsed time: 2 seconds
