Error on save - string index out of bounds
I have been using Sweet Home 3D successfully for a while without any errors when it failed to save the model. The automatic saves every 10 minutes had failed as well, so I know roughly when the problem started.
The error I got was
Can't save home in: /home/..etc java.lang.StringIndexOutOfBoundsException:String index out of range:-1
It had worked for some time before then, and no updates to any of the software was made during the edit session and saving to a different location made no difference.
Error message suggests it is trying to retrieve a string from an empty array. I had imported furniture models created in Blender, and one of these had no materials defined, which could be a cause. I re-imported the furniture model with a material correctly defined and used it afterwards without a problem.
So there appears to be a number of potential bugs: 1. Not warning when an automatic save fails leading to wasted edits 2. Not correctly overwriting a furniture item when importing a modified one 3. Not trapping empty string array when saving.
The version I am using is 4.1 with Java version 1.6.0_45
Is there any way to save my work or would the only resolution would be to revert to the latest automatic save?
Re: Error on save - string index out of bounds
Sorry, if you will lose the work made during your last session, but if there's a bug in your project or the program, it has to be fixed first. Please, send your .sh3d file to me if you can't open it, I'll try to repair it and fix the bug that could have provoked this error.
It's not a problem to define no material or have no MTL file.
Yes, there are miserably still some bugs in Sweet Home 3D, and I make my best to fix them with always a higher priority given to bugs that happen during saving operations.
And interrupting your current drawing with a dialog? Note sure it's the best strategy, for problems that happen rarely.
Please, describe a way to reproduce this bug, if you're sure it comes from this handling.
It's been trapped since you got the error at the moment you save the file! I don't think you would prefer Sweet Home 3D doesn't report any issue and let you think no problem happened...
[Edit 1 times,
last edit by Puybaret at Oct 18, 2013, 10:08:25 PM]
I managed to recreate the problem, as you say it was not the .mtl file, it was caused by a parameter in the .properties file. The furniture could be used in the plan, but an error occurred when selecting "save". To solve the problem I deleted all instances of the imported furniture, corrected the furniture library file re-imported it again.
When I created the furniture library (with items created from Blender) I copied the .properties file from a more complex model and edited them with a text editor, leaving the multiPartModel parameter set to "true" which caused the error on save.
Using the furniture editor would have avoided that problem but I was doing things manually as I had another problem earlier with the way another program handled the .mtl file.
Thanks for investigating where the issue was coming from. When set to true, the multiPartModel property indicates that a 3D model file should be saved with all the files stored in the same directory as the model (like MTL or texture images). But if this property is wrongly set to true and the 3D model file isn't in a directory, it will give the error you reported. Therefore, I updated the Beta version 4.2 to silently accept that kind of 3D model at saving time, ignoring the fact that it should be in a directory of the sh3f file.
INDIA
Now a days I am facing the problem to save the render output. This problem only exist with heavy files that needs a long HQ rendering time. After Render when I click the save button the save dialog window does not appears. This bug is also exist with all the files when I click outside the application or minimize it while rendering time.The application runs in high priority CPU usage(about98%) in Task manager. Once the application failed to save, then all the dialog windows which uses save function(save work, save video render, save render image after re-rendering) does not appears. Recently I updated my java version & GPU driver I have SweetHome3D Version : 4.1& 4.2.
