Total posts in this thread: 7
Previous Thread This topic has been viewed 3837 times and has 6 replies Next Thread
hubidubi
Wall not connected to ceiling
I would like to draw low interior walls that are 1,2m high. So they are should not connect to ceiling, they just seperate two rooms.
I was able to draw the walls, but ceiling is always connected to the top of the low walls.
Any idea?
Hubi
[Oct 6, 2013, 5:41:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wall not connected to ceiling
Create a separate level for these low walls?
[Oct 7, 2013, 9:59:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Don't place room corners close to the smaller walls. Generally, it's better in your case to draw the points of the room corner by corner avoiding the small walls.
[Oct 7, 2013, 1:53:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dvader
Hi all,
I have a similar problem:
I need draw smaller wall socle in the restroom and bath. I create new wall at lower size and put it in touch to regular room wall. It looks good but if I want to see ceiling it is incorrect - the ceiling touch the smaller wall...
How to correctly create „socle“ - e.g. http://www.zednictvi-premek.cz/_files/galery/...wc-moravsky-krumlov-4.jpg
THX
[Oct 16, 2015, 1:12:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Disable magnetism and move away the corners of the room within the main wall, so those corners will be closer to the other side of the wall. The area of the room will be wrong but the rendering will be correct.
If you can't do it, just tell, I'll try to give more details.
[Oct 17, 2015, 9:33:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hubidubi
Finally I found a workaround. There is a general cube shape in the inventory. You can change the dimensions of it so it can be used as small wall. It will behave as a furniture but it's fine.
Here it is:
[Oct 17, 2015, 9:39:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Nicely done smile
[Oct 17, 2015, 10:09:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
