Total posts in this thread: 99
Posts: 99   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 389690 times and has 98 replies Next Thread
Re: Sweet Home 3D 4.2
... some helpful trace that appears in the Java console.
Trace sent by e-mail with offending model.
[Oct 30, 2013, 8:31:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks okh for the information you sent, I fixed the bug you reported in the Beta 16.
[Oct 30, 2013, 2:27:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you! A quick check and I was not able to recreate the issue (which I could under b15).
PS - I still get error messages in the Java Console though - anything I should look for?
[Oct 30, 2013, 4:38:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sweet Home 3D 4.2 is out. Thank you all for your support. smile
[Oct 31, 2013, 12:11:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Thank you for version 4.2. I´m afraid I found a problem using Ubuntu 12.04 and Oracle Java 7.
The program starts normally and allows me to open files created with the beta 4.2.
However, when I try to open files created with an earlier version (I tried files created with 4.1 and 4.0) there´s strange behaviour:
1 - When I open a file created in v4.1 or v4.0, the program seems to close. Strangely enough the tab that indicates a program is running stays active, and when I use System Monitor, the program is shown as active as well. However, there is no way to make the program display anything. I have to use End or KIll to terminate the program.
2 - When I first open a file created with a beta of v4.2, and then open a file created with an older version, the program instance showing the v4.2 file stays active and accessible, but the program instance of the v4.1 or v4.0 file doesn´t come up and is not accessible. Again, the only way to terminate those instances is to use the End or Kill command, which of course also ends the correctly running v4.2 instance of the program.
[Oct 31, 2013, 5:04:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you, and congratulations.
[Oct 31, 2013, 8:38:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hans, how do you run Sweet Home 3D? With Java Web Start or the Jar executable?
[Oct 31, 2013, 9:11:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
I always use the installed version, that´s the 881 byte file.
[Oct 31, 2013, 10:01:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The installers versions still use Java 6 (information shown in About dialog), but it would be astonishing that it could provoke a bad interaction with Java 7 installed in the system. I'll check...
[Oct 31, 2013, 10:12:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
The webstart version opens every file I try without problems.
Haans
[Oct 31, 2013, 11:05:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
