How to copy furnitures from an opened sh3d file to another one?
How can one copy furnitures from an opened sh3d file to a special place to another one?
When I copy e.g. a table from a sh3d file and paste it into another one the table might be copied to a position anywhere far away from the room. I have no idea how to get the tabel into the room. How could I do it?
Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista
Spain
Re: How to copy furnitures from an opened sh3d file to another one?
As far as I know you cannot paste to a specific location. When you paste the object appears in the same coordinates it was on the source.
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
Thank you.
OK, but how can I get the object, the furnitures to the place I want have it? Just dragging with the pointer is not possible sinsfully because of the long distance.
Spain
You can zoom out so distances seems shorter, or you can double click the object to edit its properties and there change the location coordinates.
Yes, I had tried it, but zooming out lets the distance far enough and using the coordinates didn't work, they brought the furnitures somehow to another point far away from the point I wanted have it.
Spain
...using the coordinates didn't work, they brought the furnitures somehow to another point far away from the point I wanted have it.
I just tried and the coordinates works fine. Remember that the coordinates shown on the rules are metres and the one entered on the properties dialog are centimetres, so if you look at the rules and see you want to move to 60,40 you should enter 6000,4000 on the dialog.
Ah, I didn't notice that. But I am not able to manage it though now. I would thing just copy the coordinates of a furniture being at the right position and paste it to the furniture to move, but I cannot get it to work. But I remember to have done something like that before and it had worked.
And what could I do to receive e-mails on answers to my postings? Cannot find the option here.
Spain
Just double click the object and write the coordinates of the correct place, which from the second image are approximately -278600,-450900. What's the matter with that?
And yes, you can "watch" threads. You're probably hatching this one already, but I think by default you only receive a digest mail at the end of the day. Go to your profile and then to "my watch" and edit this one to be "non-digest".
Thank you.
I copy your coordinates into the field, but when leaving it, going to the next one the old coordinates are filled in in the field again. I have any idea, why. It seems to be that numbers with max 5 digits are kapt more than 5 do not.
OK, I changed the e-mail option like you say. I have not received any notification for this thread at all. And there is no e-mail in the spam folder from this forum. I will see.
Spain
Oh, I see... it's a bug then. Even if I switch units to metres it doesn't allow to pass -1000. I hope it can be fixed for a next release.
No idea, then. I hate this mvmForum engine, it's soooooo limited!
