Setting the origin of objects
I have noticed that the center of each rectangular object defines its (0,0) point. How do I move the origin to the top left for objects? I am putting together a layout that requires that "top" edges of each object be precisely aligned. The objects are not the same size. To avoid having to do possibly needless calculations of the origin for each object, I want to move the origin to the "top" "left". Better still, set that as the default origin for all new objects.
Re: Setting the origin of objects
you can arrange objects by using the third menu rom the main menu.
just activate all of them you need and then select from the menu the option of alignment.
WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660
