Cannot select walls or furniture after creating rooms
I have had a great time using SweetHome 3D to create a model of my new house and am excited about knowing where all my furniture will go when I move, but I've run into an issue after creating rooms.
I essentially built the entire floor plan - walls, windows, doors, and furniture - for both 1st and second floor, then went back and created the rooms/floors/ceilings. After creating the rooms, I can no longer select any of the previously-created walls, doors, windows, or furniture on the FIRST floor. No problem on the second floor. I have locked and unlocked the base plan and it makes no difference. I can add furniture to the first floor and am able to select that with no problem. When I pull up the "select object" option the furniture/walls/windows/doors aren't even on the list to select.
Re: Cannot select walls or furniture after creating rooms
Please send me your file to see if can reproduce this bug here and fix your file.
susirene, your login was lost because of a crash in the forum database tonight. Please, register again if you want to write new messages. Sorry for the problem.
