Previous Thread This topic has been viewed 7100 times and has 9 replies Next Thread
greenbar
Advanced Photo Editing with Sweet Home 3D 4.x
I have just installed version 4.0 and have discovered that I cannot get the Advanced Photo tool to work in this version. I even re-installed the plug-in but to no avail.
I reinstalled my previous version (3.4) and it works perfectly. But not in 4.0. It is an item under the tools menu but when clicked on does nothing.
Anyone know of a fix or has had the same problem?
Ray Toler
[Edit 1 times, last edit by Puybaret at Jun 27, 2013, 3:51:03 PM]
[May 15, 2013, 4:30:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Advanced Photo Editing
As said in various places, the Advanced Photo plug-in is not compatible with Sweet Home 3D from the version 3.4 which already includes all its features and more, even if they are presented differently.
I wonder whether I should remove the plug-in to avoid this question which regularly comes back... sad
[May 15, 2013, 9:46:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
spakywalk
United States
Stupid question #1,000,0001 :)
How do I remove the advanced photo editing plugin? It still appears under Tools on the Menu.
Thanks for your help!
[Jun 26, 2013, 12:17:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please see the end of the user's guide. To help you find the plug-in file easily, click on the Libraries button displayed in the About dialog.
[Jun 26, 2013, 12:51:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
spakywalk
United States
Ok, that worked great.
So is this the correct "Create Photo" dialog?
https://plus.google.com/u/0/photos/1179128456...53?authkey=CITkjvm-jMi9Pw
This dialog just has the basic create photo setup. So do I need to remove any other plugins or add something else?
I am using 4.1.
Thanks, again
[Jun 27, 2013, 1:46:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Yes, that's the correct dialog. For the two high quality levels there are some controls more, but not as many as the old plugin.
[Jun 27, 2013, 2:06:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
spakywalk
United States
Thank you! Your timely feedback is appreciated!
I have no further questions, guaranteed regarding this issue. :)
Hopefully you can close this discussion now.
Best Regards
[Jun 27, 2013, 6:06:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Some controls of the plugin are also available in the compass dialog too. Please read help for further details.
[Jun 27, 2013, 11:06:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
That's right. Anyway I was rather thinking of the render related controls, which now has disappeared and only some of them can be changed by the .ini file while others seems to have become some way hardcoded settings, as for example "compute glass transparency" or "use light angle as power knob".
[Jun 27, 2013, 11:20:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
compute glass transparency became useless because the bug that prevented the light to go through glass was fixed in version 3.0.
use light angle as power knob was a workaround to control light power and was replaced by the light power value available for lights in the furniture modification dialog.
[Jun 27, 2013, 12:50:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
