Re: Cannot launch Java application... Nice one
You must be using a plugin that wasn't compiled for the Java version you use in Mac OS X. Normally, if the programmer of the plug-in prepared it correctly, it should be detected at program launch when the plug-in is loaded, but you seem to find a misconfigured plug-in. Please, open a window in the Finder, choose Go > Go to... menu item, and copy/paste the following text to go to the folder where plug-ins are stored:
~/Library/Application Support/eTeks/Sweet Home 3D/plugins
Remove all the plug-in files you'll find and relaunch Sweet Home 3D to check it works correctly. Then add the plug-ins one by one, relaunching the program each time, until you find the one that fails. Hope you can handle it and report here the wrong plug-in.
